My retirement home ideas
   / My retirement home ideas #1
Michelle K linnane
Esperance NY
JD 4103
Hi guys
For those of you that do not know me I am NOT a stranger to projects
Here is the thread when I built my place
http://www.tractorbynet.com/forums/projects/208933-project-started-2004-end-who.html
Part of plan is to sell and get enough money for some of my retirement money. But this post
is not about that but my or your retirement home! I think I have thought about a lot of issues
but this should be an interting thread on some ideas for a retirement home.
I have radiant heat in my kennel 3740 sq feet finshed and I used about 600 gallons of propane
a year to heat that floor space. My retirement will be on slab with radaint heat with a big
kitchen, family room, and living room. The BIG ROOM will have a wood stove. I will make everything
on one level and no basement with a 10 by 20 ultility room and a wood storage off that so I do
not have to go outide to get wood. I would also have an attached heated barn to the house.
I will always have dogs some kennesl will be in the mix.
But the one thing that is one my mind today about retire home is maybe building a root cellar off
the barn to keep vegetables. The root cellar will keep from having to freeze vegetables. But as this
is my retirement home I want as a few as steps as possible. This post will have many threads but
I want to do is develope my list of requirements, which is what I would everyone to reveiw first and
seem if they wish to add to.
Living space all on on level
Walk out to barn without going out side or steps
Maybe a root cellar off barn to store food stuff in
Radiant heat in barn and house
Wood stove in big common area kitchen, living room, dining room.
I would like to gather reguirements first and the build solutions will come later!!!
Think about it before you post Eddie I would be extremely interested in your ideas?
   / My retirement home ideas #2
Sounds fun - Good luck! - re connected wood storage - carpenter ants- hard to avoid burning wood- good place for cement or tin.
   / My retirement home ideas #3
Sounds like you have thought this through.Enjoy the Built.
   / My retirement home ideas #4
Michelle I wish ya luck, lots of work for sure. reading your old post on the problems sure glad I live in area without codes and neighbors who understand living there without them is worth the risk of it...
M
   / My retirement home ideas #5
Reinforcements in the walls for safety rails in the bathrooms.
Mud room, with a deep sink.
Extra room for visitors to stay.
Space for a ramp at the front door. (you just never know)
These are the things I forgot when I had my retirement house built, now I have to add on...:(
   / My retirement home ideas #6
I would try to set up outside wood storage near a door. I would try to have a door near the wood burner. Then just store an arm load in the house.
If you can locate in a place that has natural gas If possible.
Regarding a root cellar, I've heard of some that are built into a hill with a door. Then it would be able to have fewer steps down.
   / My retirement home ideas #7
Three-foot doors everywhere for handicapped access, if necessary. Maybe wheelchair-height, and otherwise accessible, counters and sinks throughout. Obviously, you need one of those outside wood boilers. I'd put in the safety rails now. Maybe a separate live-in apartment for a full time caretaker (adult child or reliable friend)?
   / My retirement home ideas #8
Make the primary entry/exit paths with outside double doors and a 4'W hall to allow easy movement with pallets or maybe a BX1500.
Two levels could be doable if you do it in split level mode with only a few steps and wide halls between floors.
Oh - and you misspelled "mispelled" :)
   / My retirement home ideas #9
Another thought. With energy prices going higher I would max out insulation, including the slab.
   / My retirement home ideas #10
My grandparents had a cellar, built in the 20's or 30's, that was built by building a structure, and then mounding dirt around it. The entrance was a tunnel, you could see the cement blocks going in. The whole thing was cement, all do on site, with a little cement mixer. Then they put earth around it, it was done with a wheelbarrow. That area, western Wayne county, had a water table about 2 feet below the surface, that's why they didn't dig down for a cellar.
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
John Deere 7130 (A53314)
John Deere 7130...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
