My Poor Battery, warm up period
   / My Poor Battery, warm up period #21
Not sure if anyone else has said it but summer diesel in a winter tractor will cause this every time. Get some additive for your fuel to stop it from jelling or getting thick and you will have a lot less trouble in the winter (if you have done this then I can't imagine what the issue is as I have no trouble with my Mahindra in the winter with temps down to -22F -- and some thought Mahindra's had problems until they learned it was the fuel because they shipped with summer fuel to winter climes)
I treat my fuel all winter. Don't know if it's necessary, but I figure it's a small price to pay for peace of mind and maybe better performance and starting.
And a $10 tarp is still better than a snow covered machine.
   / My Poor Battery, warm up period #22
A tarp is OK for keeping sun and precip off. But ensure there is plenty of ventilation or the cure will get worse than the disease.
Thanks everyone. Sure glad I asked.The idea of cycling the fluid makes much more sense. Since we've been off grid since 83 I am embarrassed to say I hadn't thought of that. What sort of charge controller do you use and how many watts is your pv pannel?I have some old Arco 35s from back in the day that I don't use but could easily recommission them for this purpose.
   / My Poor Battery, warm up period #24
Every time I go to purchase a tarp to cover that other voice keeps telling me that's x% of a shed... I know... I know...
Even a lean to is better than a tarp if you have something to build it up against.
   / My Poor Battery, warm up period #25
If its really cold, below zero, I reconsider why I'm even going outside. Anyhow, at really cold temps, -20F, the tractor starts right up and I let it sit & run at around 1500 rpm until the temp gauge is up to normal op temps. During this time I will activate the PTO and cycle all the hydraulics. In the 34 years here, I've operated the tractor at really cold temps less that half a dozen times. I can usually justify, wait until tomorrow when its warmer. Being retired provides those options.
   / My Poor Battery, warm up period #26
I'm sure I will get myself some negative feedback with this but my tractor gets plugged in if it's somewhere below -18C other than that I just glow plug it. Where I do things that might get me in trouble is once it has been running 30sec or a min I make sure it's in neutral then slowly press in the forward pedal and set the cruise control. I idle it up a couple hundred rpm and let it sit that way for 15-20 min to warm up, this way the hydrostatic is turning and warming the oil as well as putting a slight load on the engine to warm it up.
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Mini Margaritaville Truck (A55853)
Mini...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
