My plow set up
   / My plow set up #1
Hvytrkmech
I told several members a while ago I would post pictures of how I adapted an old Fisher plow to the bucket of my B7610, so here they are. I apologize for the size, I do not know how to make them smaller.
Started with the bucket mods, 1/4 plate added to bottom and 45* angle toward rear of bucket. Also added hooks and angle to the top.
   / My plow set up
Continued,
drilled holes in bucket to mount plow frame, these are 4-1/2" holes.
I took an old plow frame and mocked it up so it would fit on the 45* angle of the LA352 bucket but be pointing perfectly straight. It is welded onto a 1/4" piece of stock. I added angle iron gussets and some 1/4 stock reinforcement plate.
   / My plow set up
Continued,
Now I mounted the frame assembly into the bucket.
This is how I secured the A frame on the plow. There are no hydraulics hooked up to the plow.
The brackets I used were for putting a fifth wheel set up in a truck. I had several extra brackets so I used them. I drilled 2, 1/2" holes in each side of the A frame and mounted the brackets so the plow would not angle left or right. The only thing I did not do yet is drill 1, 1/2" hole on the A frame itself to secure the brackets and make it rigid.
All in all I am into this setup for $300.00 in materials and appx 8 hours of my time. All the welding I did on the bucket was with the bucket off the tractor.
It works VERY well.
Thanks for viewing,
Tim
   / My plow set up
A couple more pictures of the whole setup.
   / My plow set up #6
Hmm... I've been wanting a spread for my set up. What kind of spreader is that on the back? How are you powering it?
j
   / My plow set up
j
It is a Landpride 550? I don't recall the exact spreader model number. I believe it is rated to 750#s of material. It is a shaft power off the rear. I load it up with sand/salt, it works very well as long as the sand/salt is dry. If it gets wet it will not feed down to the spreader.
Tim
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A50854)
KONE CRANES...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
