My Perkins powered M-F seems a bit down on power
   / My Perkins powered M-F seems a bit down on power #11
I'm also thinking that my grass/weeds/brush is getting thicker (the Buick hubcaps are pretty much gone now as are rocks and logs) thereby requiring more power to mow what was less dense last year. This means adopting a more frequent mowing schedule to keep things under control.
This does happen.
I mow the sides of the road from July 3rd Mid September, and my first two weeks I get my best production because of how the grass is. I have to drop down a gear about mid-July to do the same work.
I have also noticed my work has gotten tougher over the years. When we first did this, we were mowing saplings, brush, ferns and crap...stemmy stuff, and I can mow that just fine. It is those flat bladed grasses that rob horsepower! As we have continued to mow, the grass has now come in thick everywhere now, so I have to drop down into A range, instead of mowing in the lower gears of B range (what amounts to gear 3 and 4, instead of 5 and 6 as in years past). On wetland grass, I have to drop down into 1st gear, and on really thick grass, slip the clutch in first gear, or take 2 mowing passes.
But that is not really power. The tractor has the same power, I can just travel faster while accomplishing the same amount of work in less dense grass.
If the OP is losing slight power, then it most likely is the fuel supply: either air (doubtful) or fuel.
Mine will lose some power when the fuel goes below 1/4 of a tank because it does not have as much pressure pushing it past the fuel filter.
I also lost power sporadically one time when a wire fell on the exhaust and had melted the rubber and grounding out on the bare wire.
   / My Perkins powered M-F seems a bit down on power #12
My guess with only 700 hrs of use on tractor is clogged fuel filter or poor fuel flow rate from tank to inj pump.
   / My Perkins powered M-F seems a bit down on power #13
Yes Jim or he might be getting used to the power . . . :confused3:
   / My Perkins powered M-F seems a bit down on power #14
I am a firm believer in start with the easy/cheap things first, like filters. Injectors are neither easy or cheap for most of us and I would have to find a lot of reasons to go there. Follow the old KISS formula.
   / My Perkins powered M-F seems a bit down on power #15
With only 700 hours, it has nothing to do with wear.
Perkins might require oil from their prone to leaking, but they will run forever.
No leaks. I have never had to top off the engine oil between changes. Wish I had a Perkins in my automobile.
   / My Perkins powered M-F seems a bit down on power #17
They put plenty of Perkins in cars and trucks...
The Perkins engine I have for my generator came from a Reefer Unit on a truck, but they were originally designed for a diesel car in 1958. In 1992 they were last made for generator units for the British Military, but are best known for use as Marine Diesel Engines. The 4.108 engines was used on everything with 500,000 made, and a 34 year production run! That is a well designed engine.
My Perkins 3 cylinder in the M-F has quite a growl to it. I wear hearing protection as a result. I have thought about a new muffler with chambers and baffles but, that might upset the scavenging of the engine when it is working under load. Any thoughts about this?
   / My Perkins powered M-F seems a bit down on power #19
I have noticed lately that when mowing areas that were done without the engine governor having to go to the limit, requires more intervention by the engine governor. The Perkins runs and starts like new without wet stacking ever, no smoke at start, no black smoke when loaded and uses no engine oil. I routinely ad a bit of Diesel Kleen to the fuel. About 700 hours showing. I'm not the original owner so I do not know the service history (valve lash setting, etc.). I have changed the oil more frequently that specified using only Mobil Delvac 1300 15W-40 and a Wix oil filter. The air filter is new (50 hours ago) and clean. So what could be causing what I perceive is a slight loss of power? Does the CAV pump need service? Do the injectors need service? Would valve lash out of spec cause the power loss? Could it be fuel grade?
Diesel experts, what's your assessment?
X4 on changing the fuel filter first. As an old retired truck driver I always kept a spare filter or two in my truck and could tell in a heartbeat when mine needed to be changed. The quality of the fuel, the cleanliness of the containers you use and the method of refueling all determine how often it needs to be done. I've owned several tractors (including a MF 231S) and IMO Perkins are the best diesel engines out there for farm equipment. I (almost) wish my Kubota had a Perkins.
Well Mr. Bone, your Kubota engine is also high quality and well designed. I have a small disp. Kubota diesel engine that powers the 7.5 kw generator in my motorhome. It is very reliable and quiet.
2000 Sterling L9513 Winch Truck (A55315)
2000 Sterling...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
UNUSED FUTURE FT-VB59 59" HYD VIBRATING BUCKET (A57193)
UNUSED FUTURE...
New Holland T2420 (A53317)
New Holland T2420...
Scag Mower (A50324)
Scag Mower (A50324)
SET OF PEMBERTON FORKS (A52707)
SET OF PEMBERTON...
