My orange review and bad mood
   / My orange review and bad mood #21
Go with the 3010 you will be much more happy with the larger size and get a box for the rear of the tractor for both a counter weight and also to help loosen up some of the dirt.
A pile of dirt thats 100'x4'x4' contains 59.25 cubic yards of dirt.
gordon
   / My orange review and bad mood #22
Franco,
I just checked my B21 with a TL421 front loader. The maximum lift height is 88.8" (ground to the bottom of the bucket). The reach @ maximum height is 20.5"(front of the tractor guard to tip of bucket)At 68" the reach is more like 30". The maximum height with the bucket in full dump is 66.5". I think this loads your 68" truck. You can almost clear the side with the bucket in full dump, but that won't get any dirt in the truck/w3tcompact/icons/smile.gif. The backhoe makes a great counter balance~1000 lbs hanging out behind.
FRANCO,
I HAVE A B2710. TO LOAD COMPACTED DIRT REGARDLESS OF THE SIZE OF THE TRACTOR I WOULD USE A TOOTH BAR. A BUCKET WITHOUT A TOOTHBAR IS LIKE TRYING TO EAT CORN ON THE COB WITHOUT TEETH. I CAN ALSO DIG A HOLE WITH THE LOADER TO BURY THE TRACTOR./w3tcompact/icons/smile.gif
FRED
   / My orange review and bad mood #24
Yeah Fred,
I can too, but I use the scarfiers on the boxblade to rip the soil and the bucket to load it. My M6800 weighs about 8000# and the boxblade about 1000#. With 68HP and 4WD, I can push a lot of dirt with the loader, but the scarfiers are much more efficient and MUCH stronger than using teeth on a bucket to dig with. The loading height goes up with each increment in loaders. There is a reason for this. To maintain stability with 2000# of dirt 10 feet in the air, you need a wide stance on the tractor wheels and a lot of weight on the ground.
   / My orange review and bad mood #25
Franco,
I recently purchased a NH TC45D FWD-R4's w/16la loader. I also added a 72" WOODS box scraper with scracifiers. I can easily break undisturbed ground with the loader and quickly grade with the WOODS. I went through much of the pre-purchase angst your describing. I originally planned to purchase a 30hp compact..... glad I didn't. The additional weight and horsepower of the TC45D made all the difference in the world!
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
7018 (A59228)
7018 (A59228)
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
