My old polaris 500 cant cut the mustartd!
   / My old polaris 500 cant cut the mustartd!
Well thanks guys for your posts! I have always run Polaris and until this year it has been a great machine. My concern is if I start putting money in to tires and clutching etc... Where is the point when it would just be better to get a larger machine???
   / My old polaris 500 cant cut the mustartd! #12
I'd say that if you want to run well in the muskeg then you need something other than stock tires no matter what machine you get/have. Most (all?) UTVs run the same size tires on their 500's as their 900+ machines so a bigger machine only means more HP and speed. With crappy tires on a bigger machine you'll just get stuck deeper, faster. A lot of the folks that run in the deep mud/gumbo/muskeg run big tires. Big tires are heavy so more HP to the ground is good and higher performance clutching helps get it there. Mandatory? No. Just better.
You should really stop by a Polaris dealer and check out the new XP 900. It's a whole new beast with the Rzr 900 motor but tuned more for torque instead of top end.
I say check the UTV specific forums and talk with folks running the machines you're interested in that are in the type of terrain you are running in.
I just went through the Polaris web site and l I can find is the 850's. Is the xp900 brand new for 13??
My mistake pwright, I was thinking there was a new quad coming out. That xp looks impressive. If I was in the market for one that is at the top of the list.
Ok with all the great responses, any recommendation on mud tires???
   / My old polaris 500 cant cut the mustartd! #18
I've been pricing the mud lites and they tun about $850 installed here in alberta
   / My old polaris 500 cant cut the mustartd! #20
That must be with new rims, right? The tires should be in the $100-$120 range I hope. Could go with less attractive but cheaper rims.
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
Hustler super Z zero turn (A56859)
Hustler super Z...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
2016 Chevy Traverse SUV (A56859)
2016 Chevy...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
