My new Yanmar YT359C
   / My new Yanmar YT359C #21
I love the new style Yanmars. I have kicked the tires on the YT359 several times. Lots of nice features, great ground clearance, lots of power with a big Cu. In. naturally aspirated engine. But two things put it out of contention for me. Price. The local dealer must really love that machine I guess. And, the GPM on the main hydraulic system being rated at 9.4GPM. Too low for what I need. I have plans to use a hydraulic auger on the backhoe stinger, so I need at least 11 GPMs, preferably 12. I guess that new transmission takes up a lot of hydraulic power. B.
The transmission is completely separate from the main hydraulic pump, so this has no impact to the main pump's performance. I think the difference here is that Yanmar chose to have separate steering and main hydraulic pumps. I imagine they figured they would need less output, given that the steering wouldn't be drawing from the main pump. I remember doing some comparisons between the YT359 and the 4066R. If you sum the two pumps you get similar performance on the two, but I suppose that a single pump has the advantage that if you are parked and running the implement(not steering), you get the benefit of the larger flow.
   / My new Yanmar YT359C #22
Just a note:. Nearly all modern CUT machines run separate system & streering pumps. Just FYI
   / My new Yanmar YT359C #23
This little snippet from the latest 4066R brochure led me to believe there is a single pump, but maybe it is not worded correctly.
   / My new Yanmar YT359C #24
My guess is that's their total combined output for the two pumps... I think JD and Massey have the two top output pumps in the CUT segment, both around 12gpm. They probably just wrote it that way for marketing purposes
   / My new Yanmar YT359C #26
very nice i just got a yt347c , still trying to learn about it
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
PALLET OF MISC (A58374)
PALLET OF MISC...
2019 Kaufman Pro Series Car Hauler Trailer, VIN # 5VGFE4736KL004723 (A57453)
2019 Kaufman Pro...
