Chipper My new Woodmaxx WM-8H wood chipper
   / My new Woodmaxx WM-8H wood chipper #51
Just tack in some small angle or flat stock to hold it where u want. Just leave a little space to keep it easy to set back in.
   / My new Woodmaxx WM-8H wood chipper #52
Ta daaaaa. Great lab report, thanks. I think down the road sometime I will do something just like this.
   / My new Woodmaxx WM-8H wood chipper #53
I had the opportunity to do some chipping in wet/damp conditions on Monday and ran into some issues. The first symptom I noticed was a cyclical groaning or creaking noise. Initially I thought a bearing might be going bad but then I saw the bottom hydraulic motor "flexing" as the roller turned. After inspecting the roller further I noticed the two metric pea-sized set screws had backed themselves out and were gone. These screws fix the bearing (opposite the hydraulic motor side) to the roller shaft. Not good, luckily Ace Hardware had the 2 set screws I need for 65 cents each.
I theorized there might be a build up of debris causing the flexing so I set out to remove the bottom roller and clean out the debris. This involved removing four bolts and a little finesse. Typical wrenches might be too thick to hold the head of a nut in place but luckily I had some older and thinner open-ended wrenches to help. A standard socket wrench will get the bearing side off, but a crow's foot or socket swivel will be needed for the pump nuts.
It will also help to lift the top roller with the pull down handle and stick a block of wood under the 'lift arm cross tube' to hold it up and above the bottom roller.
Once you get those nuts off and remove the bearing holder, hydraulic motor, and roller, its easy to clean out the damp and caked-in debris that is causing the creaking, groaning, and flexing. Everything will go back together as it should and you can then replace the 2 pea-sized set screws.
The moral of the story is, if its damp out or you expect to be working in rain showers, find something else to do in-doors instead of being outside wood-chipping. :D
   / My new Woodmaxx WM-8H wood chipper #54
I actually like chipping in the rain. It keeps the dust down.
I'll have to check mine for those screws.
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2003 Ford F-350 4x4 Service Truck (A55852)
2003 Ford F-350...
2011 26PS PROWLER 5TH WHEEL RV (A55745)
2011 26PS PROWLER...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
