my new tractor- manual vs hydro
   / my new tractor- manual vs hydro #31
Re: my new tractor manual vs hydro
Trev:
Does that mean you have also never seen a tractor with only a hand brake.
Merry Xmas
Egon
   / my new tractor- manual vs hydro #32
Hi Egon,
<font color=blue>Does that mean you have also never seen a tractor with only a hand brake.</font color=blue>
No, I have never seen one of those either. I really need to get to an antique tractor museum someday and see some of these things.. they sound fascinating!
Merry X-mas back to you!
Bob
ok so the n.h dealer tells me to buy gear tc35 and the kubota dealer says 3410hst hydro.what hp will do it all [bailer]ect.we have a lot of rototilling/ground leveling to do and we need to tile 2 acres with a bachoe.love the kubota hydro[drove great] and the n.h. look awsome the seat is realy nice but not so sold on there hydro maybe i should test drive the tc40d [it's only money right?]thanks for all the input.how about your recommedation on the hot model in 33-45 hp range.what h.p./model will do it all?bws
   / my new tractor- manual vs hydro #34
A Landscape friend of mine who owns a large landscape company a while back switch from Kubota's to all New Holland and when i asked him his opinion on this same topic, manual Vs. Hydro he said without a dought to go hydro. He said all his tractors were manual but now will only buy hydro. The main reason was because to fix a clutch was $2500 each time and the hyrdo's almost never go bad and no clutch problems.
   / my new tractor- manual vs hydro #35
$2500 for a small clutch in a tractor ?
Where I work we just put a clutch and pressure plate in a tri-axle truck with a 350 HP Cat motor for around $1000.
Sounds like your friend was being robbed !
   / my new tractor- manual vs hydro #36
Oops,
Made a mistake.
Clutch and pressure plate for a Ford 9000 with a 3406 Cat.and 13 speed $700.
Throw out and pilot bearing around $100.
Me and one other employee 1 day labor around $300.
Total $1100 out the door.
If their getting $2500 to put a clutch in a small tractor I should become a dealer.
   / my new tractor- manual vs hydro #37
Others may need to speak up here, but I was told you need a MINIMUM of 50hp for a haybaler plus 5-6000lbs weight. Apparently the mechanism that packs the hay uses a lot of HP and the motion/weight of the implement can push an inadequate tractor down a hill.
Mark
gonna look at the john deers today in 35-45hp range with hydro trans,4x4,fel,r1's.i will try to drive it.will post test drive tonight.bws[cant buy till i ride all [3]green,blue,orange.bws
   / my new tractor- manual vs hydro #39
When you test the shuttles, there are two types: PowrReverser and ePowrReverser. The first is mechanical and the second is "fly-by-wire" electronically controlled. Of all the mechanical shuttles I drove (and I drove many), I thought the PowrReverser was the smoothest of any brand. I felt "out of touch/out of control" feelings when shuttling with the ePowrReverser. Try them both and let us know what you think.
Mark
   / my new tractor- manual vs hydro #40
If you want to do it all and run a baler I would highly suggest getting a utility tractor. I've run a baler on my 4600 but it jerks it around alot and it's hard on it. I had a friend that ran a kubota on one and his pto went out and kubota would not cover it.
24017 (A56859)
24017 (A56859)
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
