careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,840
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
My 63 Ford 48Hp. and I use a Aux. Hyd. pump FEL. My 3pt works ASIS which is Hydraulic even back then. Several ways you can setup another Hyd. pump. Old school, Crank shaft adapter. Pump shaft driven off the Eng. water/Alt. pully to a pump. Not hard to setup or one using the 3pt. also for that matter. And your tractors Hyd. should still work ASIS.. JS. But your saying the tractor won't lift it or use it without a Hyd. pressure problem. To much weight?
