My New NX4510
   / My New NX4510 #11
I have the same tractor and once you put some time on it.
It will work perfect.
   / My New NX4510
I will let you know since yours is a 2017 like mine, that I just had a warranty defrost kit fix installed to take care of a no heat w/ AC on condition.
While I was plowing snow this past year, I would have to cycle between the cold AC (to get windows defogged) back to heat only to warm ME back up. The fix is supposed to blow hot air while the AC compressor is engaged just like your car. If I turned the hot/cold dial all the way to hot w/ AC button on, I still only got cold air. Took them a little over an hour and they did it in my driveway rather than hauling into the shop.
Thanks for the hint. I tried my AC tonight to help with the defrost. It is about 20deg F here. When I hit the AC button, it blew cold for a few seconds, then when back to hot, and the AC light went off. Pushing the button doesn't seem to do anything now, and AC light will not come back on. Not sure if I blew a fuse or what happened. Didn't have time to investigate. Anyone have this happen?
On the plus side, did the first real thing resembling work (with the tractor that is)...lifted 800 lb out of my truck bed. That wasn't gonna happen with my little Kubota. NX couldn't even tell there was anything there to lift. Note to self....gotta get some forks. Lifting a pallet out with straps underneath it and wrapped around the bucket was a pain, but it worked in a pinch.
   / My New NX4510 #13
Could you expand on this some please. Mine fogs like mad.
   / My New NX4510 #14
Did someone say Kioti NX with a 3rd function installed?
Time for a Wicked 60 grapple!
400 pounds of Eat it Up.
Travis
   / My New NX4510 #15
Basically, the compressor has to run to remove moisture, understandably. But, while the AC is on, if you turn the temp all the way to hot, it apparently doesnt switch the blend from cold to hot.
The warranty fix included a new wiring harness along with a new control panel for the cab. New one LOOKS just like the old one. Took them a little over an hour to install.
   / My New NX4510 #16
Ok thanks because mine just fogs up like mad so this is good info.
   / My New NX4510 #17
edit- @ EA with the grapple photos
can you share a close up of how you mounted the tool box on port side and the handles for fuel and oil on the starboard side?
looks good. thanks
   / My New NX4510 #18
looks good. thanks
Thanks! The tractor belongs to Patrick, who is in the EA Channel Group. I'll post a couple of still captures from a video he posted, but you're welcome to join and ask him!
Travis
View of the toolbox.
This S hook looks to be what the gas can was hanging on.
Another random pic from the video.
   / My New NX4510 #19
Now that I see the photos it's a "duh" moment.....
Love that perfect 20-20 hindsite I have...lol.....
Thanks for the ideas. I be dropping by thanks for the invite!
   / My New NX4510 #20
Welcome to the pack. I have almost 500 hours on mine and no problems to report. Other than no "buddy seat", hope someone from Kioti reads this stuff.:laughing:
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
UNUSED RAYTREE RMSC78 78" HYD SOIL CONDITIONER (A57193)
UNUSED RAYTREE...
(2) 12" X 35# X 108" (1) 12" X 35# X 164" I BEAM (A57192)
(2) 12" X 35# X...
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
