My New Machine???
   / My New Machine??? #241
Did you make it all around like you originally planned to do?
   / My New Machine???
Hi Larry - Not even close. :( I ended up at Woodbury at 3PM rather than Noonish... so I was already 3 hours behind schedule at that point. Then I stayed there longer than expected checking out the bush-hogs and examining the factory hydraulic thumb installation on a new 509 they had there. The "kit" is more complicated than I thought it would be... so it was important to understand exactly what I was getting and how I could install it. I ended up leaving there well after 4PM. I had no choice at that point but to blow off my other planned stops and head straight home. :eek:
BTW, the Yanmar CBL40 wasn't there. Bob had already taken it to some fair. Funny thing about CT... they have an aggie fair just about every weekend! :)
Dougster
   / My New Machine???
I was shocked that it came in a good-sized wood crate with numerous unexpected parts. It truly is half a full installation kit rather than merely a "cylinder kit" as one might expect from the name. I'll have to sort it all out this weekend to figure out what else I need to buy for a complete installation. I also sense that a lot of those parts in the kit won't get used because of the approach I'm taking.
Well, it turns out that half the parts I received in this "kit" aren't even remotely relevant to the hydraulic cylinder installation. It appears that someone at the Bradco factory added the wrong installation hardware to this crate. :rolleyes: Now I am wondering if I got all the stuff that should have been in there. :confused:
The usual "luck" of the Dougster continues. :rolleyes:
Dougster
   / My New Machine??? #244
Dougster
Dougster,
I am right up there this week on luck with you. ;) I accidently dropped a good size stump on a stabilizer and scratched the chome on the cylinder rod. :eek: It made all kinds of noises when I retracted it. I washed it down and priced a rod..................not available. As long as I keep the rod clean, it doesn't moan and groan. A new cylinder is around $500. So for now, I make sure no dirt gets on the rod, as it might get in the scratch and contaminate the system. I will be dragging the Big Red Beast to the hydraulic shop to see if they can rechrome the rod. Oh yeah............a seal rebuild kit is about $54 for that cylinder. I am also planning on making some "shoes" for my stabilizer feet to help support the Big Red Beast in the mud. They will be 3 inches bigger all around and out of 3/8 thick plate.
hugs, Brandi
hugs, Brandi
   / My New Machine???
bindian said:
Dougster, I am right up there this week on luck with you. ;) I accidently dropped a good size stump on a stabilizer and scratched the chome on the cylinder rod. :eek: It made all kinds of noises when I retracted it. I washed it down and priced a rod..............not available. As long as I keep the rod clean, it doesn't moan and groan. A new cylinder is around $500. So for now, I make sure no dirt gets on the rod, as it might get in the scratch and contaminate the system. I will be dragging the Big Red Beast to the hydraulic shop to see if they can rechrome the rod. Oh yeah...........a seal rebuild kit is about $54 for that cylinder. I am also planning on making some "shoes" for my stabilizer feet to help support the Big Red Beast in the mud. They will be 3 inches bigger all around and out of 3/8 thick plate.
hugs, Brandi
Hi Brandi - My Bradco Parts Manual does show that cylinder rod as being available as a replacement part: Part No. 86606. That's kinda troubling if it is no longer available. I'd contact Bradco directly to confirm for sure. I've found that Mahindra dealers sometimes have mysterious problems ordering Bradco replacement parts. I think it relates to them having to go through the Mahindra parts ordering system rather than dealing directly with Bradco. :confused:
Like you, I am not real happy with the smallish "Grouser" pads that came on my stabilizers. I would much rather have had the flat pads, rubber pads or flip-over pads... if for no other reason that it would be easier to place something under the pads to avoid excessively damaging a client's yard.
I also tried to buy those nifty stabilizer cylinder covers a while back... also from a new local Mahindra dealer. They called me back two weeks later and essentially admitted that they didn't know how to order Bradco parts. No joke. :rolleyes:
Dougster
   / My New Machine??? #246
MtnViewRanch said:
I am not familiar with haying at all, but doesn't the hay need to dry some and not be bailed wet. If bailed wet, does not the hay go bad, (mold etc)? Or is this hay ok for cattle, just not for horses? Everybody out here always tries to keep their hay dry.
Just wondering.
Kieth_B said:
How do you preserve hay that green? If our square bales (the smaller type) are too wet they will heat and sometimes rot if they don't get enough air. As a kid in Ohio the local dairy put up some green alfalfa and grasses, as silage; but I've not seen anything that green baled. Is there some fermentation process it goes through, like the silage does?
Ok, I can see where the confusion is comming in, You guys are only seeing a step of the process. The final step is to wrap the bale in a type of poly film. The wrap keeps all the oxygen out of the bale. This keeps it from molding. Kieth this is just like silage without the silo or feed bunker. The bale cooks or pickles itself inside the wrap. Smells like S@$^ but the cows go nuts for it. I'v opened bales put ot in the feeder and the cows would roll in it if they could. I'll see if I can get out today and take a picture of a wrapped bale or two. It might help to understand.
   / My New Machine??? #247
Makes perfect sense, with that info. With the poly wrap cutting off the oxygen it is going to ferment just like it would in a silo, only on a smaller scale.
   / My New Machine??? #248
Dougster
Dougster,
Yes, that is the part number. My salesman called the number on the parts book, which is Mahindra. A call to Bradco is definitely needed. My problem with the grouser pads is the reach and strength of the 511. They don't dig in enough and are too small to be working in semi soft mud. If you reach too far out and hook on a large root, it will slide the tractor on the pads. I have to get close and pull up with the bucket on large roots, so the weight of the tractor and the hoe force is working together against the root resistance and down on the pads.
hugs, Brandi
   / My New Machine???
bindian said:
Dougster, Yes, that is the part number. My salesman called the number on the parts book, which is Mahindra. A call to Bradco is definitely needed.
It's *got* to be available. All just a matter of time, money and knowing the right folks to call I'll bet. :) That rod must get damaged all the time. My stabilizer cylinders are a mess... mostly from the previous owner. That's why I thought the covers might help avoid more damage.
hugs, Brandi
Well, I understand the concept. They are trying to prevent motion in two planes... front-to-back and side-to-side... but they are simply much too small for softer soils as one would find in a homeowner's yard... and apparently down on your Texas estate as well.
Dougster
   / My New Machine??? #250
Dougster
Dougster,
When I am working too boggy an area, I maneuver misc. roots with the bucket so the stabilizer can sit down on the root. :cool: It takes a while to prefect this task. ;) Less lateral movement also.
hugs, Brandi
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
2006 International 9400i (A52128)
2006 International...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
