My New Lights
/ My New Lights #1
paccorti
Hillsboro Virginia (near Purcellville)
TC35D with 16LA Loader
Finally I got this roll of film developed! Here are my new lights. First the unassembled package. Note the tiltmeter in the center (all part of the xmas upgrades). The two lights on the upper right are Hella Blue Ions. They might be great lights but they are worthless for tractors (they have a narrow broad fog light beam). I replaced them with Blazer lights similar to the one large grilled light in center. The main light mount is a steel "C" channel 3' long by 3/4" high by 1.5" wide (available at Home Depot). If you look closely, you'll see the u-bolts that I bent myself.
Peter
/ My New Lights #2
Peter, turn those lights on. I can't see a thing /w3tcompact/icons/smile.gif
/ My New Lights #4
... much better, but I had no idea Lord and Taylor sold tractor accessories /w3tcompact/icons/laugh.gif
/ My New Lights
Here is the finished installation. Switches are on the dash. Installation did not require any drilling or modification to the tractor (not even a cut wire). I attached to the electrical system using fuses and wires to the battery.
/ My New Lights
If you look closely you'll see the chainsaw box. An Echo 16". Here is the night-time view.
Peter
/ My New Lights #7
Very cool looking /w3tcompact/icons/cool.gif How high is your garage/barn door? Or is it a folding ROPS? I'd thought about lights on top like that but would make some funny marks on the garage when I tried to pull in.
Nice work /w3tcompact/icons/smile.gif
/ My New Lights #9
Good looking job. You may start a trend!!!!!
<P ID="edit"><FONT SIZE=-1>Edited by banjobj on 02/07/01 10:28 PM (server time).</FONT></P>
/ My New Lights #10
Looks like you got some good candle light power.
Have you consider some sort of guard to protect your lights from objects,for low limbs cost $$$...ouch.
Thomas..NH /w3tcompact/icons/wink.gif
/ My New Lights #11
Very nice setup. How did you mount your switches? Also, what did you use for switches?
I just put a light on my snowblower. Had to drill a hole in the dash. The switch was a rated-for-outdoor use that I got at Home Depot - can't really tell from your picture, but maybe yours is the same. Also picked up a little rubber cover that screws down on to the switch. You don't even realize the cover's not part of the original switch/w3tcompact/icons/smile.gif. I,too, have to get my film developed /w3tcompact/icons/frown.gif so I'll have to wait on the pictures.
<font color=green>mark</font color=green>
/ My New Lights
Thanks for the kind words everyone.
I haven't really considered a way to protect the lights from branches. In my case, all my trees are in one area (and they are big) so I don't have a lot of low hanging branches to dodge. If I had a welder, I'd weld some square tubes around each light in a simple rectangular configuration.
The switches are visible in the first picture (they are on the paper in the upper right corner). They are simple lighted rocker switches available from TSC or Trak Auto. My NH has plastic plugs that I can knock out of the dash for additional switches. I'm not sure if my switches are weatherproof or not. Since my tractor is garage kept I'm not too concerned about it. I just drilled a hole in the knockout and connected my switch to it. I have one switch for the forward lights and one for the rear. Rear light is a flood, front two are trapazoids. One last comment, all three lights can easily swivel (and I left enough wire for that) so I can have all three facing forward or whatever. As much as I'd like to have a canopy, it will be hard to give up the folding ability of the ROPS (when a canopy is installed).
BTW RobS how do you like your 790? I came real close to buying one of those.
Peter
/ My New Lights #13
Peter, I was thinking of attaching something to that big cross member of the FEL for my chainsaw. That would be a good place that would be out of the way and easy to get too when needed. Also, I wouldn't forget the saw when I was done for the day /w3tcompact/icons/smile.gif
gary
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2019 GREAT DANE CS1-1314-21053 53X102 DRY VAN TRAILER (A59912)
2019 GREAT DANE...
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
2025 Wolverine MSG-11-44W 44in Stump Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
DOBBS 48in Forks and Frame Skid Steer Attachment (A61572)
DOBBS 48in Forks...
