My new EX50 is here !
   / My new EX50 is here ! #11
Plan for an EX50 with loader and full cab next year.
Can you tell me is the loader function truly independant of the rear hydraulic valves.
i.e If you use rear hydraulic valves, loader does not move.
Thanks and enjoy your new machine.
   / My new EX50 is here ! #12
I cannot imagine why there would be any connection between the rear remote and the loader valves. I am not sure but the EX50 looks pretty close in size and style to my DK40se. If that is the case then there is no connection between the FEL ciruit and the rear remotes for sure. If you are using the rear remotes to control the 4n1 then obviously there is a connection but only for the opening and closing of the 4n1 bucket.
i am not sure if you mean the 3PL or rear remotes, but if while i lift the 3PL i try and lift the load frame the 3PL will stop moving until i stop lifting the loader, it must have a demand valve that favours the loader over the 3PL, not sure what happens with the remotes as i only use them for blade tilt etc, if you like i can try it out for you ??
cheers
xcat
   / My new EX50 is here ! #14
Thanks, that would be great.
I plan to pipe one of the rear remotes forward to the loader area to operate a grapple.
So I'll have the loader function on one lever, and operate the grapple with the rear remote lever.
Best wishes again with your new machine.
I checked it out tonight for you and the rear remote does stop when lifting the load frame ( same as for the 3PL ), i wouldnt think that would slow you up that much ?
cheers
anyway
xcat
   / My new EX50 is here ! #16
XCAT, I really like that set up you have. The bucket looks like it will be one handy tool with many uses.
Do all the Koiti's come with white rims in your area???
Do you have alot of mud or loose soil where you live...those tires have some Nasty tread on them?:eek:
Looks cool though.:cool:
Wishing ya many happy hours.
   / My new EX50 is here ! #17
cheers
anyway
xcat
Thanks XCAT.
This won't cause a problem.
2019 Caterpillar 249D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2017 Hitachi Zaxis ZX130 LCN-6 Hydraulic Excavator (A57453)
2017 Hitachi Zaxis...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A56435)
1992 Ford L900 Cab...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
