My new DX40 is home.
   / My new DX40 is home. #21
Sharp looking rig,congrats and the best of luck with it.
   / My new DX40 is home. #22
JHTFarmer said:
3. Get a set of QA pallet forks. This will greatly expand what you
can do with the loader.
I will agree. Until I used a set of pallet forks, I had no idea how useful they are.
Bob
   / My new DX40 is home. #23
JHT,
I couldn't agree more with the pallet forks. I've got a set with a quick attach loader on my dx33.
As for your 2nd suggestion: "take the lights of the rops". I've already got a cracked lens on mine from a tree limb.
One question for you on your dx40. Does filling the rear tires effect the performance of the tractor any? Just wondering if this causes any noticable loss of horsepower, especially on grades. I always attach my rear blade, (an older blade built much heavier and in my opinion better than any today) but still run into stability issues using the pallet forks at full load if not on very level ground.
JK - New to the forum
DX33, 72" mmm, lx114 loader, post hole auger
   / My new DX40 is home. #24
Why doesn't New Holland change thier name to Blue Holland and Case IH change thier name to Red Holland :D:D:D
I know I know get a life!:p
Pretty tractor Indiana and nice looking spread to boot.
   / My new DX40 is home. #25
After braking one of my lites ,I got smart and took off the lens ,removed the bolts ..Then turned the lites to the inside ....Everthing still works and the attack branches can't get to them ..Also looks better...I'f you pull the nut fromthe lite assy ,drill hole thru and use regular nut may have to use longer bolt ..Sure beats buying a new lite assy..Good luck .
   / My new DX40 is home. #26
Nice ride. I was going to suggest that you check to make sure your doors are tall and wide enough, I've seen several posts where folks have dinged garage doors etc. with rops up. Then I read where you go sit on it in the barn so evidently you got it inside ok. Yes, by all means teach your kids how to operate it. It's better that they know rather than them trying to learn on their own while your not there. What's the car doing on it's side? Sorry dad, didn't know where the brake was:confused: My daughter goes to work and shows off bruises she got from shooting 12 guage shotgun, and all the guys think she's cool. Enjoy every moment with them.
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
202482 (A54757)
202482 (A54757)
2018 PETERBILT 579 DAY CAB (A57880)
2018 PETERBILT 579...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
