My new 4550 temperature gauge not working
   / My new 4550 temperature gauge not working #1
Chuckk
Muck Cross VA
Mahindra 4550 4wd
They delivered my new 4550 with FEL a few days ago. So far I have put about 7 hours on it.
every thing seems good so far except the temperature gauge appears not to work I removed
and reconnected the wire to the sensor still no go. Any one have a test procedure for the
sensor and or the gauge so that I can try and narrow it down and have the dealer order the correct part.
   / My new 4550 temperature gauge not working #2
Hi ChuckK,
I am curious how you know that the temperature gauge is not working. I ask because I have same question on my mPower75 with 25 hours on it I have not seen the temperature gauge move this winter with - maybe just a hair's width up after a long time running - but not sure.
   / My new 4550 temperature gauge not working #3
If this is a new tractor your talking about I would call the dealer and have them look at it. Its under warranty!:)
Well I ran pretty hard for about 3 hours to see if the gauge would come off the peg and it never moved.
So something is not working
Well just trying to save a trip back to the dealer and then they will still have to order a part.
Thought there might be someone on here that could point me in the right direction with a test procedure.
   / My new 4550 temperature gauge not working #6
It's a 5V system that signals the ECU if I read the service man. correctly. Don't know how you could apply 5v to it to see if you could peg the gauge. Sensor varies the resistance.:confused3:
Thanks, I did a few tests today first I took my 12v test light and connected it to the wire from the sensor and and ground the light lit up so that tells me the sensor is is getting voltage. So then I touched the sensor wire to ground and temp gauge started to go up so I think every thing is working but the sensor. I then took my Fluke and measured the resistance of the sensor cold 2.2k after running the tractor for about 45 min I checked the sensor
again read .8k. Spoke to the dealer and he is going to order the sensor
So Does the manual you have show resistance spec of the sensor.
   / My new 4550 temperature gauge not working #8
Yes it has a sensor profile but I have no idea how to read the symbols. My best guess is 5 ohm @ 0 degree C and 50 ohm @ -40 C. Like I stated I have no idea how to interpret the graph and symbols. Maybe your dealer can copy that page and Fax it to you.:confused3:
   / My new 4550 temperature gauge not working #9
If I was you I would leave it alone . This a 7 hr tractor ? I would never **** with a dealer that will charge for pu / d on a new machine ! WARRANTY
   / My new 4550 temperature gauge not working #10
You need to call your dealer and have them contact Mahindra about this. Some of the Tier IV models do not warm up correctly. I have a thread regarding some of my experiences with my 3550. I suspect your gauge is working correctly, but you need to measure coolant temperature using another sensor - such as a thermocouple- to verify this.
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
Case 586H (A50120)
Case 586H (A50120)
Deere 410G (A50120)
Deere 410G (A50120)
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
