My new 2520 with Hydraulic Dump Power Pak
   / My new 2520 with Hydraulic Dump Power Pak #1
larry8818
John Deere 2520
Here are some pictures of my new 2520 with hydraulic dump power pak. This unit is custom converted to I-match hitch. I am using this with the 72"mmm.
  • 2520 with Hydraulic Dump 1.pdf
   / My new 2520 with Hydraulic Dump Power Pak #2
Slick setup. :)
   / My new 2520 with Hydraulic Dump Power Pak #3
Great setup. I've been lusting over the Hydro dump power pack but I can't bring myself to pay the $4700+ it costs total.. ;)
Let us know how it works.
   / My new 2520 with Hydraulic Dump Power Pak #4
Nice set up! :)
   / My new 2520 with Hydraulic Dump Power Pak #5
I noticed in the last picture that you had a DR Power rake in the background? Is the hydro dump to replace that? How does that dump? I have a Cyclone Rake commercial and with the fabric bag sometimes it's a pain to dump as grass get's clumped in it.
   / My new 2520 with Hydraulic Dump Power Pak #6
That's just too cool...:D
   / My new 2520 with Hydraulic Dump Power Pak #7
NICE!! Thanks for posting...
   / My new 2520 with Hydraulic Dump Power Pak #8
Cool looking unit. But why is the unit "custom" converted to i-match? I thought that i-match hitch is a pretty standard option on these tractors?
orlo -
In the background you are looking at a Dr. Power Lawn & Leaf Vac....and yes the Hydraulic Dump is to replace it. For leaf season coming up the leaves are up against a 6-foot mower deck, hooked up up to a 5hp power pack blower that you empty from the seat of the tractor!! Don't get me wrong, Dr. leaf hooked up to a JD430 with 60mmm is very good but this thing is just sick! It's like cheating. Needless to say, the good Dr. is currently for sale at a local dealer. As far as the dumping the Dr. Leaf vac all you do is remove the rear panel and pull a lever, it tilts back....and then have a pitch fork handy to help remove the 315 gallons of 10:1 shredded leaves and grass clippings. To empty the hyd. dump all you do is backup to where you want to empty, pull back on the scv lever and watch the container go up like a BFI dumpster truck. The container flips over the top, gravity empties it from close to 7ft., you then push the scv lever forward until the container stops back down into position and you drive away never having to leave the seat of the tractor :)
Superduper -
The unit is custom converted to i-match because that Hydraulic Dump system is designed around a standard cat.1 3pt hitch, not an i-match. A tech that I know came over and had to weld a couple of brackets on the hyd. dump frame to make the hook up to the i-match hitch possible. I did this because I ordered the optional bushing kit for my ballast box and I did not want to have to take the i-match off to switch between two if I don't have to.
If you research on John Deere, you will find that the 72 mower and the hydraulic dump are not compatible with each other due to JD not making a boot to fit a 72mmm.
The hydraulic dump is not i-match compatible
The hydraulic dump is not available on 2520 as deere makes it seem as the 2520 is too small a compact to be able to use that unit on.
   / My new 2520 with Hydraulic Dump Power Pak #10
Great looking system!!
Have you had any issues with the hydro dump on that tractor?
I am looking for the same set up on the same tractor, for a grass cutting busseness.
It looks like it is sitting a little higher than normal? Is that due to the brackets or is it just me?
Also how loud is the blower engine compared to the tractor with the mower running?
Again great job!!!!!!!
Jack
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
100 Gal Fuel Tank with Pump (A51573)
100 Gal Fuel Tank...
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
UNUSED TOPCAT ECSSS7G200 HYD STUMP GRINDER (A51248)
UNUSED TOPCAT...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
