My neighbors M4050
   / My neighbors M4050
I go here for starters and alternators for Kubotas. Never had one that didn't measure up. The orig part is 15601-63010. The replacement from these people is AHSND0312. In the door under $90. Similar prices on many models.
Excellent!! ... I was a bit shocked at the $500
The M4050 uses regular tractor hydraulic & gear oil from Walmart, Agway, TSC etc. A 5-gallon bucket plus another 8-10 quarts should be enough to get up on the dipstick. For the engine Rotella 15w40 is available everywhere. Take out both engine drain plugs. These engines take 7-8 quarts. Check levels after running.
I sent you PM also, but I thought I would post my question for the thread.
Are the two engine oil drain plugs clearly visible? .. I have yet to crawl under there. Sometimes those buggers are a bit hidden.
   / My neighbors M4050 #13
They are in plain view and near each other. The reason there are two is the engine has a tunnel for the front drive shaft, so there are two low point drains (common to many K engines).
Thank God for people with knowledge! lol
thanks
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
UNUSED FUTURE SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED FUTURE SKID...
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
SET OF (2) UTV TIRES, 215/65-14 (A51244)
SET OF (2) UTV...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
