My loader won't crack
/ My loader won't crack #21
RexB said:
...and Texas Rest Stop (DQ).
OK, I can translate purdy, wimmin and y'all (a very useful term) but for all us Yankees here, what is a "texas rest stop"?
/ My loader won't crack #22
I am guessing DQ=Dairy Queen -Burgers and Ice Cream
/ My loader won't crack #23
That's it! GOOD burgers 'n scream. That's purdy good for a down east guy.
/ My loader won't crack #24
Actually I am only Mid-Coast, I am not as far east as the "Down East"er's. :)
It helps that I spent 12 years in Albuquerque and 3 years in Phoenix before returning home.
Then again... what does a west coast guy know about Down East?
/ My loader won't crack #25
I lived right near Winter Harbor with the lobstermen, can't get any easter without getting wet. Dat's pronounced Wintah Habah, and don't mess with my pots *grin*
Out west here i use the little ones for crab. And my loader don't crack with hauling all the sea-stuff either - they ain't light.
/ My loader won't crack #26
Nice to know someone in Texas can speak Yankee English and understands that messing with someone's pots is akin to cattle rustling.
/ My loader won't crack #27
Hang 'em High! Swing 'em from the yardarm! And are there still enough critters in Rhode Island to rustle?
Ed, speaking of this thread "loader won't crack" kind of leads to other frontend implements. The wif allows that I need a bucket grapple because she's tired of me whining about loading logs and stickerbrush. And the bloody sheets therefrom. You've had a great grapple, Millonzi I think. So I'm spending about a grand (?) for a weldon/bolton grapple to my bucket and a remote. I've seen the threads on it but need it all spelled out if y'all would be so kind. Or point me to the particular best thread about it that i missed. I'll start a thread about it soon, right now I have to sprint to tend the brushfires and kick the dogs around.
/ My loader won't crack #28
The last time there were critters worth rustling on Prudence Island was when the British Army landed during the Revolutionary War and tried to buy supplies (sheep) from the islanders. When they were refused, the Brits shot a couple islanders and burned most of the homes before taking off with the sheep. Nice. Since then the islanders have been a bit wary of tourists who speak English. :eek:
With regard to your desire to add a grapple function to your bucket. It's nice to hear that you have seen the light. While I favor true grapples, a bucket grapple is much more useful than a bucket and chain hooks. There are a number of decent grapple arms that can be either welded or bolted to the bucket. They can be had via ebay or direct from the manufacturer. Some are made by small shops and a few by the bigger companies like ATI or Add A Grapple. You need to figure out how long the arm should be and in general a slight under bite is preferred to any overbite. Most of the people who sell the grapple arms can talk you through the appropriate measurements. The person on TBN I'd talk to is 3RRL who put a couple on his bucket. I don't really see the need for two but his set up could be done with just one arm too. If I were doing it I'd weld a reinforcement strip along the top of the bucket then weld the grapple arm bracket to that. I think that is better than bolting.
Choosing what hydraulic control system to use has been the subject of numerous TBN threads you might want to read through. I have used two of the three types most commonly mentioned. Rear remotes and diverter valve. I have not used an electric over hydraulic system but I think everyone agrees that is the cat's pajamas if you feel like shelling out $800+ t get one. If you already have rear remotes then all you need to run a grapple are two lengths of hose and QC fittings to go from rear remotes over rear axle, under operator station, up FEL post, along FEL arm to terminate on the FEL torque tube or even to go all the way to the grapple arm. You'd need to measure carefully probably using a hose or something like it as a template. As I recall it was about 16-18 feet on a CK20 to the torque tube. Using the rear remotes to control the grapple is as easy as shifting a 4 on the floor while driving. At first you'll take your eye off the grapple to look at your hand but after a few hours it becomes perfectly natural (like a 4speed shifter does). You need to develop a bit of muscle memory to just drop your hand off the FEL controller to the rear remote control and then operate the open/close. I did that happily for two years until I upgraded my CK to a DK. Never felt the need to invest any extra money into a diverter valve.
When I bought my DK I also got a great deal (independently) on a WRLong 4n1 bucket over ebay. That bucket just happened to come with a WR Long diverter valve set up complete. So, I had it installed on the DK and now use that. I do like it but it is really not a major advantage over the rear remote set up. I still have a bit of trouble with unintended movement of dump/curl when using open/close as you need to train yourself to only press and release the controller button with the FEL joystick in neutral position. I am pretty good about not pressing it (activating) except in neutral but I often find I release while the joystick is left or right which means that the grapple stops open/close but then immediately (unintentionally) dump/curls. That is never an issue with rear remotes as your hand is off the FEL joystick when operating the remotes. It also would be less likely an issue with the electric over hydraulic. In any case, the diverter is still a very useful option and it is just a matter of training yourself. The WRLong diverter setup costs something like $550-600 or so plus a half day or so of your time to install.
My advice on the controller would be to use rear remotes to start if you already have them. Much simpler to get started and you can always recycle the hose if you decide to get a diverter or electric over hydraulic.
Good luck. Grapples rule.
/ My loader won't crack #29
Dang those english-speaking sheep-swipers.
That was a good writeup and got me primed, Thanks!
I don't have a rear remote, and before getting on the horn with a manf'r, I'll
-Route a hose from the future remote location to the grapple mount and measure allowing slack for bucket curl.
-measure the grapple arm length for an underbite.
-Weld, not bolt, it on to the channel iron i welded along the top of the bucket.
-Look at both the cat's pajamas and the rear remote control valve setups and then decide how far the boss's good will goes.
-Think about a toothbar too
/ My loader won't crack #30
From the looks of your bucket you won't need to weld any more reinforcing strips! You will however need to grind off that center bucket hook. That is exactly where you will need to mount your upper jaw. Once you have a grapple on your bucket you will find fewer uses for the bucket hooks anyway so having the outside two should be fine.
You already have a backhoe so I presume you are using power beyond to run it. If you put in a rear remote or two you'll have an easier time hooking up the BH. If you put in two rear remotes you could run the grapple and leave the BH in place which is a very nice combo. Dig up the stumps and then turn around and grapple'm. I had only one on my CK20 so needed to switch out the hydraulic hoses to go from BH to grapple. A bit of a pain but not the end of the world. I would just work in an area using the BH alone and then at the end switch them out and clean up with the grapple. On my DK I can use both together and it is certainly nice.
As you don't already have any remotes, the cost of putting in a couple of remotes plus the hoses and fittings would be roughly the same as putting in a WR Long diverter valve if I recall correctly. Maybe the remotes will be a bit less especially if you do the work yourself. If you have two rear remotes you are also in spitting distance of having a hydraulic topntilt which is a nice bonus to consider.
No doubt the electric over hydraulic is the premium package. If you plan to do a lot of grapple work it might be worth it. I probably spend more hours with my grapple than with any other implement but I've still been quite content with both the diverter and rear remote set ups. I always saw the budget equation as electric over hydraulic (nice) vs rear remote or diverter PLUS another implement (nicer!). So I was never inticed to go further.
You will find lots of enthusiasm for toothbars on TBN. I had one on my CK bucket but have not added one to my DK (I do have a cutting edge). I found that while the toothbar is undeniably important for digging with the FEL, that I did not use the FEL to dig much at all. I have a BH for that. The toothbar was also useful to rip up brush but once I got a taste of grapple there was simply no comparison and I never used the toothbar again. I found the toothbar got in the way more often than it helped in other work. Nasty shin bangers too. It makes it harder to scrape up dirt from a driveway for example or to use the bucket edge to smooth out an area by back dragging. Of course you can always remove the toothbar for these tasks but that is a 15-20 minute chore and the thing is not exactly easy to store or carry around in the field. With a bucket grapple perhaps the toothbar would be more useful in dealing with brush and the two together might be synergistic. I don't know. Maybe 3RRL or one of the other bucket grapple enthusiasts can give you some insight there.
The other thing I would suggest you at least consider is whether to go with a true grapple rather than the bucket grapple. A bucket grapple setup will cost you about $400-$600 depending on how you do it. Your bucket will still be usable as a plain bucket but you will have the jaw attached almost all the time. For around $850 plus shipping, call it $1000 to most parts of the country, you can get the same grapple I have which is a perfect match for both the CK/DK line. That is a separate specialized implement and as with most things the specialized tools tend to have advantages over combo tools. You can get grapples with Kioti pin mounts so you don't need to add a QA adapter. If you decided to do a QA adapter though (more $$) then you open up the possibility of forks, tree booms, specialty buckets etc etc. Using just the pin mounts, it only takes about 15 minutes to make the switch over from bucket to grapple so it is not much more work than putting on a bush hog and much less than switching out the BH.
Just some thoughts. Good luck in your deliberations.
/ My loader won't crack #31
Outstanding writeup and you're saving my brain and back! I put my OT questions into a new thread here.
hot serving table with pan and lids (A60352)
hot serving table...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 PETERBILT 579...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
