My little Mustang pump won't work
   / My little Mustang pump won't work #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
It is a mustang pump with a little 2-stroke mitsubishi engine - got it at Tractor Supply several years ago. I think the manufacturer is Tri-Global up north somewhere. It won't pump anything at all. I finally took it apart and it did have some silt in it which I cleaned out, but I didn't see anything else wrong with it. The impeller is not what I expected. There are some fins no more than 1/8" to 1/4" thick sticking out from a flat disk, which apparently almost touch a flat disk on the other side when you put it back together. Don't know how this could work.....
The engine runs great - I hate to have to trash it and get another one. It was only about $200 but did the job when it was working.
   / My little Mustang pump won't work #2
You may have an air leak in the inlet side somewhere. That is probably the most common cause of a pump failing to start pumping. I am not familiar with that particular pump, but the shaft seal going from the engine to the pump could also be bad. Do you see any leaks when you prime it?
I will say, that when I prime the pump, the water runs out, presumably back toward the source of the water I am pumping out. But frankly it seems to have always worked this way, and would finally start pumping. But there are no leaks to the outside once you close the lid.
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
2005 Superior Trailers VT130 T/A Tanker Trailer (A48081)
2005 Superior...
2023 Chevrolet Tahoe FL SUV (A48082)
2023 Chevrolet...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2015 Chevrolet Captiva Sport 2LS SUV (A48082)
2015 Chevrolet...
2011 Nissan Frontier Pickup Truck (A50860)
2011 Nissan...
