My Little Helper
   / My Little Helper #1
Yseesee
Missouri
I've had this tractor since Father's Day 2007 and I never posted a picture of it so I thought it was time. It just went over 73 hours yesterday morning. I have been very impressed with the performance of this little beast. So far I haven't found a task it couldn't handle. Prior to this purchase I had owned a 1952 Ferguson TO30. The ease of use compared to the dinosaur is amazing. My wife wouldn't even touch the Ferguson with a 10 pole. Once I introduced her to the 2520 she wants to drive it all the time. I hate to say this but, she actually has more seat time than I do. She has taken on the job of mowing our ten acres! This is a good thing because it actually gives me more time to do other fun things with the tractor.
An interesting thing happened to me yesterday. I was moving some dirt around the property early in the morning to back fill this planting bed I'm building. The pile of dirt I was moving was frozen from the night before. Since the dirt was frozen I was able to pick up a great deal of dirt, the dirt was actually hanging off the front and sides of the bucket. I thought this was great because I wouldn't have to make so many trips. Wrong!! I almost rolled it on its right side when I tried to get back on the driveway. :eek:
I took the same path to the house as I did a few days ago when I moved a couple buckets of dirt and didn't have any problems. I found out there is a fine line between a safe load and one that isn't so safe. I didn't have the ballast box on the other day why should I need it now??? Well, I was in a hurry and didn't want to mess with those stupid wire clip thingys the other day so I didn't load the ballast box. Conclusion, from this day forward I will NEVER use the front loader without the ballast box installed! It's better to get the job done safely and use a little more time than not get the job done real fast!! OH, quickly dropping the bucket to the ground prevented the tractor from flipping on its side :D
   / My Little Helper #2
Great picture, thanks for sharing!
You should get a I-Match hitch so hooking up that ballast box will be easy! Operating the FEL without it is dangerous for you and your expensive machine.
   / My Little Helper #3
Great picture and post, thanks for sharing it with us! :) Remember, shiny side up!
   / My Little Helper #4
Great picture, great machine! I agree get a I-match or some other quick hitch. My rear tires are filled with fluid so I can get away without the ballast box for some chores. Have fun with it, that is when your wife lets you use it!!
   / My Little Helper #5
Something I wish I had thought of years ago, but will only work if you can keep your ballast box on a hard, smooth surface: Get a furniture dolly and when you remove the ballast box, set it on the dolly. $16.99 at Harbor Freight, and it makes reattaching the ballast box so much easier.
   / My Little Helper #6
Great pic...nice to see she's having so much fun!
   / My Little Helper #7
I made dollies for all my attachments , ballist box and box blade. i got the wheels from tractor supply. now all i haft to do is back up to the garage ,
and roll them up to the IMatch and off you go...;)
Chris.....:)
   / My Little Helper #8
Great picture. Can't figure why you're building a stone wall in front of the brick front you already have.
Yes, NEVER use the tractor FEL with a load in it without having SOMETHING on the 3ph. I was in a hurry one day, too, to unload some sacks of stuff. Took them down the hill without anything on behind. Almost tipped it over at one point.
Why the heck are you mowing 10 acres? I'd let about 8 or so go wild. Just mow spots, maybe trails where you need to go. Let some native trees grow. Plant some shrubs. Wildlife don't like mowed spots.
Ralph
   / My Little Helper #9
Nice tractor!! I think we all found out fast that the weight box is a must. I have mine full with 700 lbs.
   / My Little Helper #10
Ralph
Cause he's got enough HP on that 2520! :)
2002 MACK RD688S DUMP TRUCK (A54756)
2002 MACK RD688S...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
(2) SQUIRREL CAGE FANS (A54756)
(2) SQUIRREL CAGE...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
Morra MH540 4-Beater Teddar (A50775)
Morra MH540...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
