Backhoe My latest project
/ My latest project #1
harleyboy
alvinston ontario canada
Kioti ck30hst
When i brought my backhoe home I only got a 12" toothed bucket and decided a 24" ditching bucket would be very useful. So i removed the bucket and drew up prints and over the last month at work and home i now have a new bucket that works great.
HB
/ My latest project #3
Two comments:
1. Awesome looking job, looks very handy!
2. Your backhoe is WAY too clean!!!!
/ My latest project #4
Nice work! ...sooo ..when can I come borrow it?:)
I assume you are going to give it some dentures?
/ My latest project #5
HB
You really should post this on the Build-It Yourself forum. Very nice, wish I had one.
/ My latest project
Thanks guys
As for your questions,
No teeth it does a great job when you only want to skim off the top and leave a nics clean bottom thats undisturbed.
I used 1/4" plate all around with 2x 3/8 edging on the cutting lips and 1/2" on the mounting.
As far as cutting it out I use our high preasure water jet at work! it helps when you have access to a full machine shop.
HB
/ My latest project #8
Great job on the bucket. It looks like a factory original, just without the teeth. There are times I wish my bucket didn't have teeth for those nice smooth cuts but sometimes harder rocky ground needs the teeth to help with the digging. Apparently Bobcat has bolt on teeth for their loader buckets. This was posted in the Bobcat forum. Maybe if you needed teeth at times, they would work.
A high pressure water jet sure does a nice job compared to a burning torch. If you could use your work equipment more often, you probably could start a little business making buckets. I'm sure there are a number of guys that would like a smaller or larger bucket.
/ My latest project #9
HB
Cheater.
Nice job.
/ My latest project #10
What would you estimate the cost of materials for your custom made bucket to be?
And about how much labor time did it take to assemble from start to finish?
Thanks!:)
Nice job.
/ My latest project
Material was about $100-$120
Labour hard to say but i guess around 10 -12 hrs
Thanks everyone
HB
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
2022 FORD F-450XL FLATBED TRUCK (A64277)
2022 FORD F-450XL...
8x18 Meyer 1200 H Farm Wagon (A65579)
8x18 Meyer 1200 H...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
