My Lady Scared a few years out of me today!!!!
   / My Lady Scared a few years out of me today!!!! #1
Hoosier_Daddy
Platinum Member
Indiana
New BX2200 4-3-02 (traded 6-08) new B2620 06-08
Deb wanted to mow the lawn before the Rain showed up so I got the BX2200 ready for her. We have a walk out basement so there is a hill on the west end of the house to get from the front lawn to the basement level.
From the basement level there is also another hill to the back yard. So we are dealing with 3 hills with lawn on all three but they come together in a terrace kind of arrangement.
(You come down one hill from the front, on level ground a bit and then go down the second hill.)
She started mowing at the basement level and when done with that was going to go up to the front yard. I told her to put the tractor in low gear with 4WD to mow up the hill and when she got to the front yard she could put it back in 2WD and high gear.
I went into the house. For some reason, (her Guardian Angel told me to check on her?) I went back outside at the basement level and watched her go up the hill.
She got up to the top level, stopped and was switching to high gear when all of a sudden down the hill she comes backwards.
Zigging back and forth to keep from going over the steep hill down 3 levels she did fairly good trying to back track where she just came from. I ran to her yelling "BRAKE BRAKE BRAKE"..... She just kept coming down faster and faster...
I caught up with her half way down the hill and then ran on along side her with my hand pushing the brake. The tractor lever was in neutral. She was free wheeling.
She said she got used to the HYDRO and forgot the Brake was even there. It happens.... So, we had a refresher PRE-Flight Course before she resumed mowing..
The whole incident didn't seem to bother her. I, on the other hand, am sitting here reliving the incident as I type. Still makes the hair stand up on the back of my neck. Guess I am getting soft in the older years.
And, my hand kind of hurts from when she did finally stomp on the Brake with my hand still on the Pad. It happened so fast just like it always does.
I am thanking God she didn't get hurt. She said she is thanking God she didn't hurt the Bota.
Tom
   / My Lady Scared a few years out of me today!!!! #2
Did the same thing on my BX, Parked on a hill and set the brake and shut it off. To restart you have to put in netural and removed brake. That was my backward downfall or should i say downroll, need to put in gear before removing parking brake,and you cannot get it gear when you are freewheeling! Only thing damaged was my pride. What do TBN'ers think about removing netural switch on hydro's so i can start in gear.
   / My Lady Scared a few years out of me today!!!! #3
Indeed that would make anyones ticker pump little faster. /w3tcompact/icons/shocked.gif
Glad it all turn out well for you tho,also your wife to continue enjoying the BX.
   / My Lady Scared a few years out of me today!!!! #4
Tom -- Please pass along my congratulations to your wife. Backing at high speed is a skill my wife doesn't possess. In fact, she uses the "back up till it sounds expensive" method. I am truly impressed by your wife's presence of mind!
Pete
   / My Lady Scared a few years out of me today!!!! #5
I'm so glad you wife was able to get a handle on her BX so quickly...
by the way what tractor are you getting for yourself... /w3tcompact/icons/wink.gif
   / My Lady Scared a few years out of me today!!!! #6
Yet another good example for always wearing the seat belt.You never know what might happen,even when just mowing the lawn.
Sounds like an eye-opener for sure.
   / My Lady Scared a few years out of me today!!!! #7
You have to remove the park brake before starting?Better double check that,the BX should start with the Hydro. in neutral and park brake engaged.
On our G1900 the safety switch is on the brake peddle,it won't start unless the brake is engaged.
   / My Lady Scared a few years out of me today!!!! #8
glad it all worked out with no harm done, and you and your wife safe. amazing how fast things can go to hell quick!
   / My Lady Scared a few years out of me today!!!! #9
are u sure u have to take parking brake off to start tractor? that don't sound right. any bx owners that can add to this?
   / My Lady Scared a few years out of me today!!!! #10
Yes, it will start with the brake on, i just had brain fade and kicked the brake off before starting. Then once it got rolling i could not stop with the brake, it just slid the wheels.
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
