Dealer My Kubota dealer went Big with his stocking replacement for my 7040
   / My Kubota dealer went Big with his stocking replacement for my 7040 #1
Lyrch75
Leetonia, OH
ZD331 and RTV1100
Drove by my local Kubota dealer on the way home Friday and noticed what looked like a huge tractor sitting up under the giant open air greenhouse he uses as a lot.
Had to back up and check it out. M110x is now sitting between the little L series tractors, and while it isn't a huge tractor by the scale of most farm equipment it looks gargantuan in the setting it is in. Its front tire is the same size as the rear of the L it is sitting beside :D
I checked it out while I was there, as I had never seen one of their fullsized ag tractors up close, and came away fairly impressed. Everything that needs to be beefy was. Nice sized cab, although not JD big, with finger tip controls and everything seemed to be a good spot ergo wise.
Took a couple of cellphone pictures, but they came out crap so no visuals, sorry.
   / My Kubota dealer went Big with his stocking replacement for my 7040 #2
Took this off the Kubota site. Hard to lose that in a field.:D
   / My Kubota dealer went Big with his stocking replacement for my 7040 #3
Several years ago I sat in a M9000 and thought it was a monster compared to my little L4330. At the Farm Show in Louisville last spring they had a M130 and the size was really awesome for a Kubota. They seem to be creeping into the mid size ag tractor range more and more. It will be interesting to see how they do.
Enjoy your new tractor!
   / My Kubota dealer went Big with his stocking replacement for my 7040 #4
My dealer has a New M135X Cab on his lot......thats a Fine looking tractor!!
   / My Kubota dealer went Big with his stocking replacement for my 7040 #5
We have two of the bigger Kubotas on the farms I cant remeber the model #s but for what we do with them they are not built strong enough. Both have had issues with the draw bar and front ends. If you are doing light farm work I think they would be just fine but every day loader work they are disipointing to us.
Rob
   / My Kubota dealer went Big with his stocking replacement for my 7040 #6
Rob
That's a common complaint often heard about the larger M series Kubotas.
   / My Kubota dealer went Big with his stocking replacement for my 7040 #7
I've heard that on the internet but everyone I have ever talked to in person loves them to death. The M-100/110/120 are a very popular dairy tractor here. The New Holland TL's and 35 series are the mythical "my buddies friend has one and has put 3 axles in it from loader use"
My own Massey 5455, a common beef/dariy tractor in europe with a good reputation has had a front axle failure in its past.
   / My Kubota dealer went Big with his stocking replacement for my 7040 #9
Yikes, I've only ever seen hydraulic pump failures on these things. TL's that is.
New Holland B95 Backhoe (A50490)
New Holland B95...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
