My Kubota backhoe attachmenthas stopped moving from side to side
   / My Kubota backhoe attachmenthas stopped moving from side to side #1
bentemand
Huntsville, On
Kubota / B20 w/backhoe
My Kubota B20, 1991 has a backhoe attachment. The side to side swing movement, only, has stopped working. The backhoe is equipped with a side limitation switch (if I'm pronouncing that right). previous to the problem I replaces all the hydraulic FLUID. Shortly after that the problem started to develop.
Can anyone shed some light on this? Appreciate it.
   / My Kubota backhoe attachmenthas stopped moving from side to side #2
Does your BH valve have a solenoid connection on it anywhere, especially in the swing circuit?
If the voltage from the limiting switch goes to the solenoid, then is is a protection device to limit swing, and if it fails, then that circuit may not work, and inhibit any swing.
Can you show a good picture of the BH valve?
Thank you so much for your reply. To be honest I know very little about hydraulic but my son will have some time in June /July and I would appreciate it if I can contact you again. My son seems to understand what you are talking about.
Tanks
Bent
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
UNUSED LANDHONOR SD-22-72W NO TILL SEED DRILL (A54757)
UNUSED LANDHONOR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
JLG 1255 Telehandler (A55218)
JLG 1255...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
