My Kubota backhoe attachmenthas stopped moving from side to side
   / My Kubota backhoe attachmenthas stopped moving from side to side #1
bentemand
Huntsville, On
Kubota / B20 w/backhoe
My Kubota B20, 1991 has a backhoe attachment. The side to side swing movement, only, has stopped working. The backhoe is equipped with a side limitation switch (if I'm pronouncing that right). previous to the problem I replaces all the hydraulic FLUID. Shortly after that the problem started to develop.
Can anyone shed some light on this? Appreciate it.
   / My Kubota backhoe attachmenthas stopped moving from side to side #2
Does your BH valve have a solenoid connection on it anywhere, especially in the swing circuit?
If the voltage from the limiting switch goes to the solenoid, then is is a protection device to limit swing, and if it fails, then that circuit may not work, and inhibit any swing.
Can you show a good picture of the BH valve?
Thank you so much for your reply. To be honest I know very little about hydraulic but my son will have some time in June /July and I would appreciate it if I can contact you again. My son seems to understand what you are talking about.
Tanks
Bent
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
2008 Ford Ambulance (A47477)
2008 Ford...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
