my kk brushog is still new and trashed?
   / my kk brushog is still new and trashed? #31
<font color="blue">...is there suposed to be some give in this A frame assambly?... </font>
Hi Paul,
The "U" shaped swivel for the top link helps for the up/down movement... but only the design and strength of the A-frame help the side/side movement...
Cutting a field of grass is no problem... the A-frame would probably last forever...
However, cutting brush and moving through the brush is where the A-frame really takes a beating (hours upons hours of twisting and turning... you don't realize how tough this brush can be over time)... you have to remember the 3-point rotary cutter is "just long extension" of the tractor... driving through the thick & nasty brush and turning puts the stresses and strain on the rear coupled area... notice how thick the tractor's lift arms are (mine happen to be CAT II)... they don't flex like the steel in the A-frame does...
Again, it boils down to distortion/fatigue of the weakest link... /forums/images/graemlins/smile.gif
   / my kk brushog is still new and trashed? #32
John,
It's like comparing a Ford Ranger Pickup to a Ford F350 Super Duty when one compares a KK to the Brown pictured.
   / my kk brushog is still new and trashed? #33
</font><font color="blue" class="small">( (check the KK manual, website, pictures, advertising, etc... and I think you'll find multiple ways "they" (KK) assembled that A-frame... ) )</font>
I will check around. So far the only things I've seen were the product brochure, and the instruction manual, which both show the same.. supports on the outsid eof the lip.. but I will deffinately browse around and look.
If that frame has been pounded on and restraightened alot.. then it is probably on the weakerside now. Might not every be as strong.. might be a light light duty brushog now...
Soundguy
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
UNUSED PABREAK CM385-55" HYD CONCRETE MIXER (A57193)
UNUSED PABREAK...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
UNUSED FUTURE HYD MINI AUGER (A57193)
UNUSED FUTURE HYD...
2008 40ft T/A Gooseneck Flatbed Equipment Trailer (A55852)
2008 40ft T/A...
