My JD3103 Starter Relay smoke - please help replace it
   / My JD3103 Starter Relay smoke - please help replace it #1
cangiupsuatractor
trenton, nc
John deere 5103, 5075E
I. Here is what happening:
1. Battery bad.
2. removed battery.
3. hold up charger directly to + and - cable.
4. start the engine once (did not start)
5. buy new battery, installed it. the engine cranking but no start even though the ignition key is at off position. disconnect the battery.
6. disconnect the wire from ignition (starter relay?) to the starter.
7. connect battery. After 2 minutes i see smoke comes out at the starter relay.
II. Need help:
1. what is wrong with my JD5103?
2. look like starter relay shorted. if that is true, should I buy and replace it or bring to tractor to the dealer?
III. I am new to this, so please forgive me.
thanks
Andrew
It is JD 5103 instead of JD3103.
Thanks
   / My JD3103 Starter Relay smoke - please help replace it #3
Are you blowing any fuses? And does the fuse blow as soon as you turn the key?
If yes, to both questions, I believe the problem is the thermistor sensor. On the thermostat housing there is a sensor that is connected to a two wire harness that goes to the injection pump; this is the "cold start advance" portion of the system so it starts easier when cold by advancing the timing.
If you disconnect the sensor and it works fine ohm test the sensor, probably shorted.
The sensor on the thermostat housing controls the advance on the injection pump. When it fails it shorts out and blows the fuse. Try unplugging it, replace fuse and see if it starts and runs. The part # is RE503242, if you are quick changing it, you don't have to drain the coolant, just make sure it's not hot at the time. You will want a pan under the tractor to catch the coolant, so as not too have to clean it up.
You may need to re-prime the fuel system, if it still does not start
To comply with the exhaust emissions regulation, the timing of injection pump should be around 6 to 9 degrees before TDC. These timing values do not allow proper start-up operations when engine is cold. To ease engine start-up, a cold advance system gives to the injection pump a temporary over-timing.
When coolant temperature is below 50ーC (122ーF), the solenoid valve is activated and opens the cold advance circuit.
My tractor (5210) has a relay which keeps the fuel solenoid from opening, if you connect a wire directly to the starter to keep it from starting. I am guess yours is the same and that is when trying to start it the way you are doing will not work.
Also if you have no smoke, you are not getting any fuel, which would again confirm what I think is wrong.
URL to JD parts
jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
   / My JD3103 Starter Relay smoke - please help replace it #4
II. Need help:
thanks
Andrew
From #5 you say connecting the new battery caused the starter to turn the engine, but no start and the key was OFF? Sounds like the starter relay is stuck/burned "ON"
From #7 you say the relay is smoking after two minutes. Sounds like the relay is shorted or not meant to be "ON" continuously.
I would start with a new relay and see what happens.
It turns out the wires that connect to Starter Relay burn and short together. I would appreciate very much for any help locating this part and how to replace it.
   / My JD3103 Starter Relay smoke - please help replace it #6
Part's key #6 RE234727 Starter Relay
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2014 LAMAR TRAILER (A53843)
2014 LAMAR TRAILER...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
