My JD STX 38 just died!
   / My JD STX 38 just died! #1
survriggs
Missouri Ozarks
Kubota B7800
Lawn needs mowing...had a short amount of time to get it done...start the 8 or 10 year old STX 38 (black deck)...mow 2 minutes and it dies. Spark is OK, took off air cleaner and cranked to see if gas present when choked and it was. When cranked it backfired through the carburetor with lots of noise and flame. I put the air cleaner back on and cranked again. It tried to start but never would get up any rpm's. I realize that analyzing what I've written is no substitute for an experienced hands-on repairman but the lawn still needs mown, It's coming up on the Labor Day weekend and I don't want to use the push-mower. If this is a recognizable symptom I'd appreciate any ideas........also,I've also got my eye on a new JD X300 or CC GT2542. I kinda have my fingers crossed that it's shot....it's easier to explain the new JD or CC to the wife.
I'm not a frequent poster but a frequent reader and I've gotten a lot of good info. at TBN, thanks.
   / My JD STX 38 just died! #2
Once I had a B&S that would start and die after a few minutes. I did a carburetor kit job and it cured it. It could also be something in the electrical that gets hot and quits. Did you check spark immediately when it stopped?
it did have spark immediately after it stopped. I am in process of checking sheer pin on flywheel although I can't remember any incident where it would have sheered.
   / My JD STX 38 just died! #4
A backfire can shear the flywheel key. I have seen it many times since i have repaired mowers for years.
   / My JD STX 38 just died! #5
I would go with the sheered pin idea also.
   / My JD STX 38 just died! #6
Did you get 'er fixed? or buy a new one?
1985 CADILLAC SEVILLE (A53843)
1985 CADILLAC...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2014 MACK GU713 DAYCAB (A53843)
2014 MACK GU713...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
