My Industrial Cabin Build
   / My Industrial Cabin Build #4,922
You aren't taking off the nut that causes sad music on a hillside in a few days, are ya? :oops:
Oh no. Not messing with those. I’m also gonna have to figure out what to do with the old piece. While I’m at it, I have an old fuel tank from this excavator that I need to get rid of.
   / My Industrial Cabin Build #4,924
I have a Ryobi impact to take bolts like that apart.
i have a Ryobi from HD that works good on bolts like that. Over 1000 ft pounds to remove bolts.
   / My Industrial Cabin Build #4,925
What size saplings can the Ventrac comfortably cut? In my experience with rotary mowers, the manufacturer's specs are always highly optimistic, and cutting anything as large as they suggest is pretty abusive on the machine.
If you can push it down, you can pretty much cut it, but yes, it can be abusive to the machine.
1 inch is easy pickings. 1.5 inches is not too bad. The issue is usually how many at a time you are trying to g to tackle. That can make a difference. When going after 2 inch popler i usually push them over and cut them then pull the whole thing out by hand. Trying to mulch a 2 inch tree is asking for a blade to get broke. Off or some other issue. It certaimly cant cut the material that my 8 foot rotary cutter on the kioti 7320 does. But it is also much easier to avoid stumps, etc with the ventrac
   / My Industrial Cabin Build #4,927
Does that idler wheel run on bearings like a bicycle or is there grease fittings to keep it lubricated ? Take the old fuel tank you have and make it into a parts washer tub !
I believe it is bearings. I’ve never seen a zerk, and it rolls pretty well.
A parts washer would be interesting but I’d be afraid to cut into a fuel tank.
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
RHINO X1808 LOT NUMBER 43 (A53084)
RHINO X1808 LOT...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
