My Industrial Cabin Build
   / My Industrial Cabin Build #4,891
Called and talked to shop. They will look at it but suspect bent rod. Part starts at $850 and is out of stock. Not what I was hoping.
He also told me “dont go unscrewing that big nut or there will be some sad singing on a hill in a couple of days.
Get the shop to take it apart. They are equipped to do that safely. Take the "bent" rod to a machine shop. They can buy chrome cylinder rod and make you a new one. I'm pretty sure it won't be $850 either.
I drove into the Valley with the Idler assembly. The I bought my excavator is a bobcat dealer now. The Komatsu dealer across the road used to be a Risch Komatsu but apparently they’ve changed names three times in the last few years. The guy was nice. Took a look at it. Told me if they can pull it apart and it isn’t bent, they can rebuild it for $650 unless it’s a real bear to tear apart. Said if I can get it apart the seal kit is $250. I brought it home and tried to get track cylinder arm out. Put it between tractor and pickup truck and was cranking on it with
4k lb come along. Absolutely no movement. Tried pumping grease into it also. Nothing. With that big spring, I’m not keen to beat it with a sledge or put a bottle jack in there and get stupid. I’m gonna suck it up and see if I can find a bigger shop in richmond that has a press that might be able to break it free. I cant win every time
   / My Industrial Cabin Build #4,893
Does that mean you took the big nut off?
No. If you pull on the piece that has the wheel, it should come out of the spring piece. Mine is stuck. That nut would require a substantial hydraulic press to remove. I am not trying to get that unscrewed. I’m trying to get that wheel assembly and rod out of there
   / My Industrial Cabin Build #4,896
Dude, pay the nice man. Sure, look around and see if you can find someone else that might be better/cheaper, but that thing has major pucker factor in it... Now maybe you can DIY the other side as a PM now too, assuming it is still working, but I know you are more concerned with getting going ASAP
   / My Industrial Cabin Build #4,898
I was not injured and nobody else was injured except the doe. I expect the insurance company to disappoint me but that too will pass. I came home to my dogs wagging their tails, my daughter telling me about her day at work and my wife made me dinner and drank a glass of wine with me. My life is pretty fantastic.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
Wright Sentar (A50120)
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
