EddieWalker
Epic Contributor
I was going to fabricate something since I didn't want to spend that big bucks to buy anything. I have pallet forks and hay forks, so I flipped the hay forks to be vertical and hooked the quick attach to the ends of the pallet forks and hold it all in place with a chain and ratchet.That stretcher bar is cool but what are you using to move the fence around?
I had to create a massive 3/4 inch plywood washer for the fence wire to spin on that works great. The picture shows my first attempt at the plywood washer. It was too small and if the wire got loose, it would slide off the washer and tangle in the hay spear. The bigger one is a lot bigger!!!
I attach my fence wire to my wood corner post with barbed staples, and then drive backwards. The wire unwinds until I'm out, then I install the crimp sleeves on another roll, and keep going.
I'm using these crimp splices from Amazon. Kenco also has them, but Amazon is faster and easier to order from. I put two of the C34 10.5 gauge sleeves on the top and bottom wire since it's so much thicker, and a single C2L-Long sleeve for all the smaller wires. I double crimp every sleeve. I'm not very impressed with my crimper, but I'm not sure what to get that will be better. It's not very smooth, or easy to use.
And the very best thing I've come across for attaching clips to the t-posts is the Clip Bender. I had to watch a YouTube video to figure out how to use it, but once I figured it out, it's been awesome.
