My Industrial Cabin Build
   / My Industrial Cabin Build #2,661
   / My Industrial Cabin Build #2,662
   / My Industrial Cabin Build #2,663
I have the constant pressure valve system from CycleStop on my Grundfos well pump. It does have a tank (I have the optional larger tank on mine) that you draw from for low demand (less than 0.5 hon iirc) until the pressure drops below cut-in at which time it will refill. At higher demand you get the constant pressure that the valve is set to.
Really like my system-constant pressure is really nice.
I should correct myself. The direct pressure system comes with a 4.4 gallon tank that is attatched to a small manifold, which can be mounted to a wall. I have a 40 inch space just inside the door to the mechanical room where I could mount this to the stud wall and free up enough floor space for a water softening filter system.
After reading, my only concern is power. I will be on the grid but we are end of the line. Have you had any issues with the drive?
   / My Industrial Cabin Build #2,666
Not sure what you are asking-if you’re asking about the ‘drive’ part of a VFD well pump-I don’t have a VFD pump-the constant pressure valve (CycleStop) valve is used with a standard constant speed motor.
I put up a video this morning.
Ok. Yeah I am really liking the idea of the extra space I would get with the VFF. Entry coat is less. Future costs are higher but It would solve my issues.
   / My Industrial Cabin Build #2,669
Evidently you did not read about the cycle stop valve that I posted up thread :(.
   / My Industrial Cabin Build #2,670
With the constant pressure valve you get all the the benefits of the VFD without all the added cost and complexity.
I have run my pump off of my generator. So I still have water and most everything else when power goes out.
My system shown below. CycleStop valve is red item in photo
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2021 Chevrolet Tahoe SUV (A55853)
2021 Chevrolet...
40006 (A55788)
40006 (A55788)
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
