jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 20,387
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
I was clearing brush along the property line of a tract I have for sale. My method was to back the rotary cutter into the brush and then use a bypass-loper to cut limbs up to 1-1/2" diameter.
I was in a particularly thick bunch of postoak and blackjack oak trees when suddenly my HST pedal froze. I tried the reverse pedal, but of course, it was the same, frozen solid. Aargh!
Here I am, buried in brush and my tractor won't move. Thoughts of how I could ever get the tractor out of there were racing through my mind.
I shut down the rotary cutter and got off the tractor to inspect the pedals. Back when I first bought the tractor, the attaching point to the transmission had broken and the pedals would not work, but the pedals moved freely with that problem. Their movement was just not getting to the transmission. This problem was different like something stuck in the pedal mechanism and keeping the pedals locked. Working in the brush, I expected to find a limb stuck in the pedals, but to my surprise, there was nothing there. I really began to get a sick feeling in my stomach.
So, I climbed back into the seat and pushed really hard on the pedal. The tractor moved slightly and slowly forward and I realized the tractor could creep out of this mess by itself, but I was sure afraid I would bend the pedal if I pushed too hard. I had a flash idea and reached down to flick the Rabbit/Turtle switch to Rabbit. Sure enough, the tractor moved a little faster just as it should normally. Instead of the joystick switch, I reached down to the fender Rabbit/Turtle switch and flipped it back and forth. Perfect! I was going to be able to get that tractor out of the brush to work on it.
Just as I was flipping the switch and watching the orange light on either side of the toggle, something caught my eye. What's that? It's. . .well. . .the cruise control green light is On. Wait! I flipped the switch to Off and WALA! The pedals suddenly worked normally. DOH!!!
A limb had pressed on the cruise control switch just as I had lifted my foot off the pedals. This effectively locked the pedals in neutral.
There was nothing whatsoever wrong with my tractor, just jealous brush that wanted to press buttons as I drove by. Woohoo! I'm a happy guy.
EDIT: Thanks to the moderator who moved this post from Buying/Pricing to Owning Operating. I was going to do it, but my connection slowed to a crawl. By the time I got back here, you had "done the deed" for me.
