DiezNutz
Hey now don't waste those...
DiezNutz said:Every one is a little different, but this doesn't sound abnormal to me. Was it always like this or has it gotten detectably worse in the 10-15 hours you've used it?
Sure does. Maybe not as bad as these guys' BH75's by the sound of it, but then maybe more so than yours. I honestly can't say I ever timed it though. It varies with a couple of factors like, which bucket I have on it, did I leave it parked in the hot sun, etc. It will always droop a couple of inches in a half-hour or so, then it plateaus for a while (think as if there were some "play" to be taken up). I'm going to guess after it hits that plateau it droops less than an inch an hour. This is only the boom, the stabilizers aren't as "droopy". The BH80-X boom is more massive than the BH75, plus I got that thumb on there, good bit of weight to hold up.BandDcabinet said:Does the Woods BH droop?
vic_salve said:I understand that minor drop is normal, something like Jay4200 is speaking of, but to drop enough to have to reach back and give it a boost every 30 minutes is too much I think. It didn't drop any at first for several weeks.
Spoke to dealer today and will be taking it back Monday. He acted like he was going to fix the thing and make it right. So stay tuned if you are interested in the outcome. I'll post the results as soon as I know something.
vic
mazurrj said:If i forget pin, i'm reaching back every 15-20min though with about 4" drop.
Jay4200 said:Just out of curiosity, where is that 4" measured? Is that bucket height from the ground, or exposed boom piston shaft?
JayC
Good question, we might not all have the same point of reference. In my earlier posts I was referring to highest point of the boom with respect to ground, tractor, whatever else. In other words, the tip-top of the dipper knuckle. Why there? When I'm on the tractor it's something I can easily see...when I raise the boom I can gauge how much the top of it dropped. Because of the boom angle, the top also moves further than the bucket when tucked in.Jay4200 said:Just out of curiosity, where is that 4" measured? Is that bucket height from the ground, or exposed boom piston shaft?
JayC
Bummer... I'm surprised to hear they allow that much. Hopefully it doesn't get any worse... or maybe we should hope it gets ALOT worse so it will get fixed!vic_salve said:Well, got my answer today. The dealership checked all the leak rates and then contacted their tech support from the factory. The factory said that they allow 2 inches every 5 minutes bleed down. The dealer agreed that seemed like quite a bit, but if that is what they call normal they can't do anything to fix it. I don't like it, but I'll have to live with it I guess.
