My fuel throttle is stuck on my 1739E Massey Ferguson
   / My fuel throttle is stuck on my 1739E Massey Ferguson #1
CptSteelHead
Indiana and NC
1739E MF 2019
It's really cold here in Indiana. I scraped snow off the driveway yesterday. Everything was fine.
Then some one was stuck last night on the hill. So I brought a load of gravel there. I turned it off.
When I restarted it the fuel was on really high, past 540.
When I turned the fuel throttle down nothing happens. I can go up and down nothing happens. It remains really high rpm.
How do I fix that?
Okay, thanks. I'll go look at it in a little bit.
   / My fuel throttle is stuck on my 1739E Massey Ferguson #4
Did you shut it down at high RPM?
Id assume not... Which would sort of rule out the "stuck" part. It would only be stuck at its last setting
So, did you shut it down at PTO RPM?
Can you get the unit to above freezing temps to rule out a frozen cable?
   / My fuel throttle is stuck on my 1739E Massey Ferguson #5
If his 1739E is anything like my 1736 it has a throttle sensor to control the fuel rate and I don't think there are any mechanical linkages. The sensor is located under the dash and I'm assuming its provides an electrical signal to the pump?
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
STORAGE FEES (A52577)
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
