powerscol
Its been raining a lot so I had a chance to put together most of my 55 gallon drum filling station.
First I used a Fill Rite RD 8 portable 12 v pump. It comes in several configurations, but I got the one with the barrel bung and suction pipe. I used stainless fittings, except for the top 90 (store was out of the SS ones) I went with the smaller pump as I dont need a lot of flow. After the pump I installed a large fuel filter (Water Block element). I went with cam lock fittings so I can remove the pump when I go to fill. It also allows the pump to swivel some. The fuel cap came from TSC. Got it out of their sale bin as the package had been opened..
I haven't filled it yet as I am still working on how to secure the barrel to my plastic pallet. I went with the plastic for long term durability. I tried just strapping it down, but the bottom will slide too easily on the pallet. I am thinking of picking up some 1.5" aluminum L channel, and slicing on side so it can bend around the barrel base and then bolting the bent L section down with bolts with fender washers to keep the barrel bottom in place. Any other ideas. The barrel used to contain ethanol so should be good for diesel per the oil dealer I got it from. The warning stickers also cam from TSC - required here.
