My Ford won't go into 4WD
   / My Ford won't go into 4WD #1
Corm
Fairfax, Franklin County, Vermont
1999 Cub Cadet 7260, 1953 Farmall Super A
My Ford won\'t go into 4WD
I have a 2000 F250, V10, standard shift, 3.73 gears, 4x4, 47k miles. I needed to use 4WD the other day, and it wouldn't go into 4WD using the hubs in the Automatic mode. I ended up having to go outside and manually lock in my hubs, after which 4WD worked fine.
When I turn the knob on the dashboard from 2WD to 4WD, I hear the familiar click in the transfer case, but don't hear the familiar clunk from the front end /forums/images/graemlins/frown.gif. Since 4WD does work if I manually lock in the hubs, is it possible that I just need to take the hubs apart and give them a good clean up and lube, or is this indicative of another, more serious problem /forums/images/graemlins/confused.gif? I've never taken apart any 4WD hubs, can't imagine they are all that complicated, but am hoping someone who has may have a suggestion or experience to share??
Thanks in advance for any info shared. BTW, this is the first problem I've had with this truck. It's been a real good rig.
Corm
   / My Ford won't go into 4WD #2
Re: My Ford won\'t go into 4WD
Corm,
Ford has had problems with the autolocking hubs. I have not
paid too much attention to the solution since I have manual
hubs.
Search through the old Ford Diesel website for the autolocking
hubs and you will find the problem and solution.
The url is ....
www.thedieselstop.com
Later,
Dan McCarty
   / My Ford won't go into 4WD #3
Corm,
I had an F250SD for a while. Yes, remove the hubs and lube them. I just used WD-40 every 3-4 months and things worked great. I used to have trouble with them unlocking at times. Removal of the hubs is easy.........just a snap ring and they pull right out.
Jerry
Thanks for the info! /forums/images/graemlins/smile.gif That's what I was hoping to hear. I'll have to wait until the first of the week till I have the time to tackle them. I'll let you folks know how I make out.
Corm
I will definitely check out that website. Thanks!!
Corm
   / My Ford won't go into 4WD #6
HI Corm, sorry to hear about your hubs but sounds like a simple fix. We hope. Have to have the rig up for camping. Take care and have a great summer. /forums/images/graemlins/grin.gif
VERMEER V6500 COMBO TRENCHER (A52708)
VERMEER V6500...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
John Deere Gator (A53317)
John Deere Gator...
1997 Peterbilt 378 Tri-Axle Heavy Haul Truck, VIN # 1XPFD69X4VN428289 (A57453)
1997 Peterbilt 378...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
