Buying Advice My First Tractor
   / My First Tractor #21
If I was looking for a SCut I would be checking out the Kubota BX-25D
   / My First Tractor #22
I was in the OP's position a year ago so I'm going to weigh in even though I don't have the experience that a lot of you other guys have....
First, I'm going to respectfully disagree with jeff9366's advice to go with a rear mount mower only. One of the main things that I wanted was a mid-mount mower. To me, it was more intuitive to use. I did test drive a couple of pieces of equipment that had rear mounted finish mowers on them and thought that with my yard a MMM would be easier to use. Like the OP, I have a lot of trees to maneuver around and the thought of that mower sticking out behind wasn't appealing. I also spoke with my neighbor across the street about the issue. He and his brother are farmers with a wide array of equipment at their disposal. For their own lawn mowing, they also use either a front mounted zero-turn or their JD 3320 with a MMM. jeff9366's statement that removing and reattaching MMM's is a tedious task doesn't really hold water when you consider the drive-over, auto attach decks currently available from Deere and others. jeff9366 - not trying to start a peeing contest here! :) Just giving a "diverse opinion" as you requested in post #17. :thumbsup:
If a mid-mount mower is important to you and you want to go with a larger frame tractor, you are probably going to be more limited in your choices. With John Deere, you can get all the way up into the 3x20 series and still get mid-mounts. I'm pretty sure that Kubota also has similar sized tractors with MMM's as an option. But, Kioti only offers a MMM on their smaller, subcompact tractor. (I did confirm that in the Kioti booth at the National Farm Machinery Show last week in Louisville.) I can't speak to options that other manufacturers offer.
I have about the same amount of property that the OP has. I started looking at a JD 2305, then graduated up to looking at 2520's and settled on a used 3520. It came with the FEL and MMM. Part of the reason that I went with the bigger tractor was that I wanted a little more "oomph" for removing and moving brush in my woods. I'm shopping for a root grapple to go on the FEL and for that reason I'm really glad I went with the larger tractor. For the OP, a 2520 sized tractor would probably do what he wants/needs for just about everything. The only thing that I'm not sure of is how it would handle a rear mounted tiller. And, a larger tractor would probably better handle a box blade for his gravel driveway.
Hope this helps!! :)
   / My First Tractor #23
Well I guess I'm going to be the odd man out by saying, you can by to much tractor. I'm going to talk Kubota because it's what I'm familiar with, first on your list is the garden a BX or B would handle a 4 or 5 foot tiller just fine. The next thing is mowing less than two acres, a BX with a 60" deck will more than handle the task and depending on how your yard is setup it can cause you to trim trees, move shrubs etc., a larger tractor? Next maintain your drives and move an occasional snow, what ever you get will do this. Tending the flower gardens same thing. As far as the backhoe the BX you would need to get a BX25 up front, the B you can add one later. The backhoe is the thing IMO a L would be nice but you have to look at your overall use of the tractor, it has to be a compromise that you can work with.
Don't sell the smaller tractors short, they will do the same jobs it just takes longer and you don't want a monster on your small lawn. If you don't like compromise you can always get two tractors.
   / My First Tractor #24
Agree and I would point out that a SCUT or small CUT running a 48" tiller would be the same HP per foot as a 30-35hp running a five foot tiller. Given the size of the OP's garden plots, a 48" tiller is more than adequate.
The OP doesn't tell us how long his driveway is or how frequently it requires grading. If it is a quarter mile long on hilly terrain with lots of maintenance required, I can see the need for a heavy boxblade and heavier tractor but if it is shorter and just requires regular touch up then a SCUT can certainly handle a lighter duty four or five foot boxblade or five foot rear blade without any problem. Why get a bigger more expensive tractor and implements to save ten or fifteen minutes of time once a month?
   / My First Tractor #25
As you see, We know how to spend your money!:D
   / My First Tractor #26
Ya, given $50k or $60k, you'll get everything we need! :laughing:
   / My First Tractor
First let me start by saying this board is great. Being able to get the diversity of knowledge and opinion in one place makes this somewhat daunting task a little easier.
Let me see if I can clarify a few items that have come up about the different tasks I foresee.
  • All the land is either grass, garden area, or mature woods. I don't foresee any need for any heavy brush clearing in my future, but I do see the need for the tractor to be able to navigate back into the woods for FEL tasks. Bringing in mulch or chips and bringing out firewood or stones.
  • The driveway I need to maintain is at most a couple hundred yards, but is on a grade. It would be nice to have something that could handle that task without breaking a sweat, but realistically it's something I would do once or twice a year (it will not get heavy vehicle use) and as long as I can get the job done (even at twice the amount of time) I would be ok with that.
  • I think in order to maintain WAF (Wife Acceptance Factor) I need to stick with a MMM. From what I have read of the JD's anyway, it appears that taking them on and off has been simplified.
My thoughts so far is to move up the ladder a bit (maybe a JD2520) to access the better hydraulics, but to stay within that size/weight range. Obviously I have not yet had any butt in the seat time, so that could change, but so far I'm finding it hard to justify the significant $$ increase to move up the next step. That being said, from what I have seen of used prices (at least with JD and Kubota) they hold their value enough that I could trade up later if I found the need to.
I'm also leaning heavily toward buying used, although probably from a dealer. If anyone has any thoughts on that I would appreciate any insight.
In regards to the BH, is it a decision I need to make up front? Are the frames different on the models that can handle a BH? Also, are BH's brand/model specific? Are there after market backhoes that may not integrate quite as tight, but may be less expensive for the few times it gets used?
Thanks again for everyone's help!
-mark
   / My First Tractor #29
[*]All the land is either grass, garden area, or mature woods. I don't foresee any need for any heavy brush clearing in my future, but I do see the need for the tractor to be able to navigate back into the woods for FEL tasks. Bringing in mulch or chips and bringing out firewood or stones.
[*]The driveway I need to maintain is at most a couple hundred yards, but is on a grade. It would be nice to have something that could handle that task without breaking a sweat, but realistically it's something I would do once or twice a year (it will not get heavy vehicle use) and as long as I can get the job done (even at twice the amount of time) I would be ok with that.
[*]I think in order to maintain WAF (Wife Acceptance Factor) I need to stick with a MMM. From what I have read of the JD's anyway, it appears that taking them on and off has been simplified.
-mark
Based on your update I would reiterate that a SCUT or under 30hp CUT would be more than enough for your tasks.
Buying used from a dealer gives you some "insurance" I suppose but at a steep cost. These small tractors are very reliable and if you have an experienced buddy to help you test out a used, sale by owner machine you could probably buy at least a couple of implements with the savings over dealer cost. If I were in your shoes, I'd keep my eye on Craig's List for a BX23/24/25 with a MMM. Probably cost about $12-16K. Very few of those CUT TLBs have been worked terribly hard as most are purchased by homeowners often just to do a few projects and then sold. I wouldn't hesitate to buy one with less than 250 hrs even if the fluids had never been changed and it was put away "wet". They are that reliable. With more hours I would want to know it had been maintained. You can test the FEL, BH, MMM and 3pt yourself and if you have tried one or two while shopping at dealers, you should be able to judge if they work.
I'd feel the same about the equivalent JD or Massey or Kioti etc.
   / My First Tractor #30
I don't understand why some of you are talking 30+HP CUT for someone who is mowing 2 acres or less. You can do that with a riding mower with less than 20 HP gas engine. Where is the need for more than a SCUT or low to mid 20's HP?
Have you ever used a small CUT? A B series Kubota or Kioti CK20 or CK27 would easily do the tasks listed on 2-3 acres. It would cost less, use less expensive and easier to store implements too. For the cost of a 30+HP CUT you can get a BX25 or equivalent and have the bonus backhoe too. A BH is much more valuable on a small lot than an extra 5-10 HP IMO. Been there.
There are certainly situations were more than mid 20's HP can be justified on a small lot but I don't see any in the OP's initial note.
I fully agree. Everyone always has this "go big or go home" attitude. Fine I guess, if you like spending money on purchase, fuel, and more oil on service day.
As far as mid mount mowers.....I like them and the drive over deck on my B2620 is extremely easy to remove and install.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
Club Car Utility Cart (A55853)
Club Car Utility...
