My first tractor
   / My first tractor #1
1stormseekr
Agnos, Arkansas
ls mt125, belarus 250as, ferguson 30
well i just drove 250miles one way last night and baught a ferguson 30 for $600. This is my first tractor should be interesting finding out and fixing it's problems. Real easy to start so far but doesnt like to stop *grins*.
So far i need to look at the brakes, does have water in the oil, and smokes.
Havent messed with one in 15years...ahh grandfather would be so proud.
well after a while tinkering in the daylight the brakes just need pads, and it smokes like a freight train. Think it needs a headgasket, but i figure i am just going to rebuild it.
   / My first tractor #2
Congratulations on the new toy! Which motor does it have? TB
   / My first tractor
z129 4cyl gasoline, is that the info your looking for? Not up to speed on the engines of old tractors...now if it was in a muscle car i am your man.
   / My first tractor #4
A continental motor. Dont know a whole lot about the continental motors, mine is a perkins. If it smokes that bad, the pistons the rings and sleeves are probably wore out. Im guessing a headgasket is not going to stop it from smoking. Someone else might have a better idea for you. Maybe the head needs work and oil is getting by the valves, that would certainly be a cheaper and easier solution if that were the case (dont hold your breath lol). I would toy around with for awhile and see how everything works before you tear it down. I dont know how bad yours smokes, but when I bought mine it was so bad you couldnt really use it without being choked out, so I rebuilt it real soon after the purchase. Good luck, and how about a few pictures of the new toy? TB
   / My first tractor #5
They are prone to cracking between the cylinders....I had two TO30's that did that. Can be plugged and/or welded.
   / My first tractor
lol choking ****, this thing kills every insect within a mile. Taking it to fatherinlaws tomorow and we will tear into it then and see what it's problem's are. I am in luck, he is a mechanic with close to 40years in the business and has a full machinest shop! *grins* It pays to stay on his good side.
   / My first tractor #7
Start with a 10 foot pipe straight up on the exaust, that shoud put the cloud well above you:laughing: TB
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2019 ExMark S-Series 72in Zero Turn Mower (A51691)
2019 ExMark...
WB Mower (A50120)
WB Mower (A50120)
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
