Oil & Fuel My first oil change
   / My first oil change #1
donjovi
Stevenson, AL
Yanmar 1700
Does anyone know what type oil is recommended for a Yanmar 1700 and how much with oil filter replacement?
   / My first oil change #2
Different folks use different brands but most agree a good diesel rated oil. I personally use Rotella 15w40 but am not saying it is the best of the best. Just good enough for this old boy.
From my readings I believe your 1700 will hold about 5 quarts with the filter. I would put in 4, crank up, circulate, let settle and check the dipstick and add as needed. Next time you'll know fer sure. :thumbsup:
   / My first oil change #3
Welcome to the site ...From AL :thumbsup:
Can't help with how much. I would say 4-5 qts. You could just add until it shows on the stick , crank the engine until filter fills. add a little more
Any 15w40 diesel rated oil will do
Well, Winston beat me to the keys:laughing:
   / My first oil change #4
Welcome to the site! I'm just down the road from you in Scottsboro. I use Rotella 15-40 in my YM1500. It's excellent oil. You can get it at Tractor Supply or Walmart in Scottsboro or in Kimball just up the road from you. My tractor takes 4 quarts but yours probably has a slightly larger engine. You can get an owner's manual from Hoye in Texas. Their ad is at the top of the page.
   / My first oil change #5
The YM1700 takes 5 quarts of oil for the engine. I agree with the "diesal rated 15w-40 oil" recommendations. I have also read people recommending a synthetic 5w40 diesal rated oil that Walmart carries. I believe it is also Rotella. It will be thinner when it is cold, which will help with start-up in the winter.
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53472)
Texas Post Driver...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
