My first 2n repaint project...
   / My first 2n repaint project... #1
dave2n9n
Detroit Lakes, MN
Ford 2n
Here are a few pic's of my first tractor repaint. It sure was a fun project. I have always had some kind of spark-plug equipment or cars to work on, I sold all my cars and now am into tractor rebuild or paint. I have been retired for a year now so it's all fun for me.
   / My first 2n repaint project... #2
Very nice. Good looking old tractor. I take by you name you have a 9N also. So when will you add the 8N?
Actually mine is a 2n, the reason why my Avatar says 2n,9n is that 2n was already taken. I would love to have an 8n to work on, but the prices just keep arising and in retirement to justify a buy would sure be tough to get it past the wife.
   / My first 2n repaint project... #4
Nice job with the paint. It probably didnt look that good when it left the factory. Have you done anything with the engine, clutch, steering, or hydraulics? I have a 1951 8n that was the first tractor I ever owned and it is still my favorite. The factory paint is starting to look pretty bad and some day I hope to paint it up like yours, but with a red belly. There is something about them old n's that has not been improved on with later models, such as ease in getting on or off either side and hitching up 3-point implements. Mine sees light duty these days and only has 1800 hours on the proofmeter. The only mechanical issues beyond points (twice), plugs (3x), and oil filters (every other year), was new tires and a valve job about 20 years ago when unleaded gas finally took out the factory valves. The factory clutch is still fine, as is the steering, hydraulics, and right side brake, not much left on the left side however. Over the winter, I use it once a week to haul a half facecord of firewood up from my woodshed to the house. That old tractor always starts right up on a couple turns of turns even though it still has the original 6 volt electric and the temp has been close to or below zero for the last several weeks. In the spring thru summer it is used on a 2-row corn planter and various odds and ends thru summer and fall. The tractors of today are pitifull in comparison to those old n's with all the plastic and electronics, and there is no way I would expect them to go so long (70 plus years) with so little trouble, and continued parts availability. If I didnt need 4wd for loader work, snowplowing, and heavy fieldwork on soft ground, I would still be very content with just a couple of n's.
   / My first 2n repaint project... #5
My brother has my dad's old 8N. What a great tractor. Good size for small farm easy use use and move round. Good power to size. My brother had his converted to 12v. It needs something, does not have the power it should. Not sure if carb or valves.
   / My first 2n repaint project... #6
63 yr for my 8n is 1948 & still go
I have not done anything to the engine other than new points and plugs, + a new radiator 2 weeks ago. I bought the tractor 2 years ago and I was told it had a top end done. The engine appears tight, it does not smoke, oil pressure stays good after engine warm up, it runs with 20lbs oil pressure with a load on. It is 6 volt and I plan on keeping it 6 volt, it starts up fairly easily at temps below -10, anything above zero it starts up with first crank. One thing I like about my 2n is it's simplicity, I grew up with no electronics and I remember what it was like to work on engines without electronics. I painted the tractor with original grey and I love it's appearance.
   / My first 2n repaint project... #8
you did a great job on that lil 2n.
   / My first 2n repaint project... #9
That 2n is lookig pretty sharp. :thumbsup: I have to say, love the red implements. :thumbsup: I have wanted to get an 8n to work on but im still trying to rebuild my Simplicity 9518 which isnt getting compression right now. :( But atleast it is a good learning experience for a young buck like me. :thumbsup:
   / My first 2n repaint project... #10
sweet! thanks for posting!
Test Button (A47384)
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
2008 Ford Taurus X SUV (A50324)
2008 Ford Taurus X...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
7' Snow Blade (A50515)
John Deere HPX Gator (A50514)
John Deere HPX...
