My Farmtrac 60 WON'T CRANK......
   / My Farmtrac 60 WON'T CRANK...... #1
Phil-DDG16
Tarmtrac-60
Won't crank...tries but acts like not enough battery. Replaced battery & starter still won't turn over. Pulled INJECTORS and it turns over just fine. No funny noises, injector pump working. Replaced injectors...still won't crank.
I have Electrical Wiring Diagram for FT-60 if anyone needs.
   / My Farmtrac 60 WON'T CRANK...... #2
Jumper the starter and see if it will spin over.
   / My Farmtrac 60 WON'T CRANK...... #3
What Gator said. The only thing left is wiring or the switch. Better to test than to just throw parts at it.
   / My Farmtrac 60 WON'T CRANK...... #4
Proper cranking speed = battery + starter + CABLES. No mention yet about your cables/connections. I would go there before worrying about switches and wiring.
   / My Farmtrac 60 WON'T CRANK...... #5
check the ground cable at the frame...
   / My Farmtrac 60 WON'T CRANK...... #6
I'd be cleaning and brightening ALL the connections. Are you even sure your 'new' battery is any good? Did you load test it?
   / My Farmtrac 60 WON'T CRANK...... #7
I replaced the starter on my 2003 and made new battery cables. That resolved the slow turnover problem on my tractor. Cranks right up everytime with nice RPM even in the winter.
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
23013 (A55787)
23013 (A55787)
Towable spreader (A55973)
Towable spreader...
5004 (A55851)
5004 (A55851)
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
