My farm pro 2420 has no power
   / My farm pro 2420 has no power #1
senior1962
2005 farm pro 2420 2WD
Can anyone help me with some advice
   / My farm pro 2420 has no power #2
I had one of those with the two cylinder ty290 engine. What do you mean no power ? Throttle running power or electrical ? Both are problematic on these. The fuel inlet is a screen in the bottom of the tank and is known to get "bugs" in it which will restrict engine power. Take the fuel inlet off and clean the glass bowl and then blow into the tank with pressurized air to clean the screen temporarily. Drain the tank of it's junk Diesel and junk in the tank.
If electrical with no power then check the fuses. The wiring is known to be sub par. Check for voltages at the fuses using the wiring diagram.
It has to be the electric I don't have the wiring diagram no manual or anything don't know how to check fluids or nothing would appreciate any help you could provide
   / My farm pro 2420 has no power #4
Check for good fuel flow from tank to injection pump. Check to be sure fuel tank vent isn't clogged. Has fuel filter been changed recently?
   / My farm pro 2420 has no power #5
Try the stuff I mentioned for the electrical. Give us some more details and maybe others will chime in on it all too.
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
