MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,581
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
EddieWalker said:For gravel roads to last any amount of time, they need to be at least 4 inches thick. If your gravel washed off the road, then it will just do it again until you get enough rock on there to hold it all together.
The second problem that caused gravel drives to fail is not having enough drainage. If the water washes over the road, it will fail. No amount of gravel is enough if you can't get the water away from it. The faster the better.
Create drainage ditches, put in culverts and crown the top of the road. When that's done, buy enough rock to get your 4 inch minimum thickness and you'll just have to worry about minor maintenance over the years.
To maintain a gravel drive, add rock. Those who drag boxblades, rakes and other tools over their gravel drives are speeding up the process of erossion. One good boxblading session can take years off the life of the road. It might be smoother for awhile, but that's just temporary.
Eddie
I tend to agree with your comments...
Why would someone want to drag scarifiers through a roadbed? It would loosen up everything that has taken years to pack down. We always had non-paved drives when I was a kid. We never used gravel, as it is round and won't lock together. Tires tend to push it out of the way and make two side ridges and one center ridge. Crushed rock or slag from a steel mill are better choices than gravel, in my opinion.
