My dealer dropped Kioti, another closed, and a third...
   / My dealer dropped Kioti, another closed, and a third... #21
BTI said:
I'm sure the only Bobcat dealers that are going to service Kioti's are the ones that are actually set up as Kioti dealers.
BTI
You are most likely right regarding warranty work but I imagine for other stuff they would do it. Do you think a Bobcat dealer would turn away a Gehl skidsteer that needed new tires or hydraulic hoses or some welding repair? If they are going to be stocking Kioti/Daedong parts for the CK series anyway there would be no reason at all for them to turn the work away (at least for the CKs).
   / My dealer dropped Kioti, another closed, and a third... #22
I should have clarified....
I was meaning Warranty service.
As far as other service it would be up to that dealer I'm sure, depending on how busy they are with their own equipment.
BTI
Called Bobcat shrewsbury this morning.
Some good things: they are carrying Kioti (orange) because Harvard dropped Kioti. Basically their North Reading store sent down the CK20S TLB because w/o Harvard power, Kioti wanted them for area coverage.
Also -- they used to be open on saturday, but as just Bobcat, not enough business which I can understand.
They plan on moving to Auburn for a better location. He hates where they are -- it is like a prison in appearance and w/ the aggregate plant next door processing rocks and portland cement all day it's nasty (smells, vibration, etc).
So -- when they move to Auburn (which is well in my range still not too far out on route 20) and pick up more Kioti stuff, it might end up worth while for them to be open on saturday.
So that's all good -- maybe it will work out.
I will be calling them after 1st of the year to order some parts -- hopefully they'll be setup by then -- they have an appointment this week for Kioti related business.
   / My dealer dropped Kioti, another closed, and a third... #24
malk315 said:
Called Bobcat shrewsbury this morning......
When you call tell them they should order and give away Kioti hats!!!;)
   / My dealer dropped Kioti, another closed, and a third... #25
-SNIP-
Come on.. sure.. when I move FROM Auburn they come in!
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
(10) 10'-6" PVC CONDUIT PIPES (A60432)
(10) 10'-6" PVC...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
