3-Point Hitch My CK2510 with a homebuilt rear carrier
   / My CK2510 with a homebuilt rear carrier #2
Very cool. What does the empty carrier itself weigh?
About 300 lbs ish. I have a 4" poured concrete "floor" which fits into the box if I just want to use it as a counterweight/ carryall, or for hauling firewood
   / My CK2510 with a homebuilt rear carrier #5
Pretty neat! Where did you get the sunshade?
I built it. Just a chunk of 3/8" plywood, easily replaceable when it gets dented by a tree.
   / My CK2510 with a homebuilt rear carrier #8
This is great. Do you have other pictures? How does the dump mechanisms work? Do you any sort of build directions?
I do not have any other pics right now, the machine is on a job away from home otherwise I could get a few for you. The dump mechanism is a simple hook-and-latch. Pulling the rope lifts the hook. The pivot is the 3 point's lower lift arm connection. Google "transport box" and you will see many similar mechanisms. The main difference this one has is that this is actually a rear pallet fork that dumps, and the box just sits on the forks.
18002 (A51691)
18002 (A51691)
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2003 Ottawa Spotter Truck (A50120)
2003 Ottawa...
2016 Toro Pro Force Towable Blower (A50322)
2016 Toro Pro...
20" Sea Container (A47384)
20" Sea Container...
