My ck25 HST stalling !
   / My ck25 HST stalling ! #1
KiotiKevin
Port Morien, N.S., Canada
Kioti NX4510
I know - it's a never ending subject but one has to apply the HST answers to their own unique situation. I'm looking for some help, please ? I run in medium range but I really have to work it by taking run at the snow and when I get too much to move it stalls. This particular day we had extreamly heavy rain for about 3 hours after the snow. I had no power going up my driveway of which is only on a slight incline as you will see. I couldn't get very far with the couple of inches of slush.
There has been a couple of ocasions when I had to rock it back & forth to get it moving in just a little bit of snow. My dealer who also sells Masseys, says they just do a small adjustmant and they are ok. Do you think it might be a valve adjustment How about a couple or a lot of views on wether I have a problem or I don't ? I'll post a few pics on my CK 25. Took me about 3 hours to move this stuff aroundfrom front to the back of the garage - I'll post some progress pics from the piece I am building in the back later. Thanks
Kevin
Just me playin I forgot to mention, my neighbour builds Cape fishing (fiberglass) Boats custumed to you needs . I did some sea trials with him they are beautiful.
   / My ck25 HST stalling ! #5
Kevin, did you have something hooked up via a remote? Make sure the connection is good. Sometimes if you have a loose connection, the tractor will not run properly. Check for leaks somewhere at the connections and other locations. Check the hydro fluid level.
You didn't have these problems in the beginning did you? John
EDIT: Also, depending on your setup if using a remote, make sure the lever that switches the fluid is in the proper position. John
It stalled getting a good scoop in meaduim range.
I still love my CK 25 just disappointed with the lack of power especially such a small grade. took me 3 to 4 hours to do this.
any info would be appreciated. Thanks again
Kevin
John,
I don't have any remote and I don't know anything about those connections or valves. I found it sluggish during the summer from digging those roots but I did most of that In low range. I called my dealer and he hasn't called be back on this issue but I plan to persue it under warranty. Thanks for responding so quickly.
Kevin
   / My ck25 HST stalling ! #10
Hey Kevin,
Do you have the throttle 'up' when the engine stalls? What RPM's are you normally running at? Are you using any type of diesel additive in the fuel to prevent gelling...during the winter months?
Don
Quick Attach Pallet Forks (A47384)
Quick Attach...
Online Buyers Premium (A47384)
Online Buyers...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
