My Ck25 HST psi ??
   / My Ck25 HST psi ?? #1
KiotiKevin
Port Morien, N.S., Canada
Kioti NX4510
As some may remember my Post in January 'My ck25 HST stalling' , I tried the increase in rpms; it seemed ok after that but I still insisted the dealer check the pressure in the HST. The dealer's mechanic was here the day before yesterday and did a pressure test on the transmission and got 3700psi, he says he was given the specs from Kioti that should read 4200psi. He agreed that it appeared lacking some HP. He said "it seems like it might be getting some air somewhere".
I recall someone here had a similar problem with a CK20.
What I am looking for is for some feedback from anyone who may have encountered a similar problem and how it was fixed. Or possible suggestions.
Down on each side of the top of the transmission (one side reverse other forward) there is a double spring (one inside of the other). He said on the Masseys (that only has a single spring) the company recommends shims which would be the equivalent to 100psi per shim.
He is going to get back to me on wether it can be repaired or not.
Any & all input invited. This, I think would be an education for everyone, It certainly is for me. Thanks
Kevin
   / My Ck25 HST psi ?? #2
Get in touch with "GeTut" he was the one who orignally had the problem and had the problem corrected by a Kioti mechanic. In one of the other threads there were a couple other folks who noticed the same problem, not sure what the outcome was with those folks.
   / My Ck25 HST psi ?? #3
The CK25/30 should have 280 bar / 4,060 (approx. according to an engineer at Daedong) psi pressure at the pressure relief valve. The dealer could: shim the spring plug, replace the spring plug, replace the whole PRV. I'm not sure why he's saying there seems to be air getting into the system. Did he say what indicated that to him.?
Rest assured that this CAN be repaired, and it doesn't take much. John
Thanks Bob.
John,
He said he found the pedal jumpy while trying to gain power.
When you say "The CK25/30 should have 280 bar / 4,060 " , what does that mean in more simple terms - sorry, it's relatively new to me ?
Is it the same amount of psi for both ck 25/30's ?
Thanks
Kevin
   / My Ck25 HST psi ?? #5
280 bar is = to the 4,060 psi pressure limits where the pressure relief will activate. If you're below that, the tractor will go into relief too soon. The pressures are the same for both models. The CK20 is 240 bar.
The way the test is done can be important to the results. Did he lift the rear tires off the ground, hook up the pressure gauge and operate the treadle pedal to get the reading?
John
Thanks John,
He wedged the snowblower against the edge of my concrete walkway and turned the bucket upside down into the pavement so it wouldn't move in either direction. Then he pressed the hst pedal forward as far as it would go with the pressure gauge attached and did the same in reverse. I think he said it should have stalled but it didn't. He said he was going to contact Kioti and get back to me and that he may have to come and pick up my tractor to take it back to the shop (3 hours away) because it also had a small fluid leak (just a couple of drips a day) in the bottom of the transmission, nothing major. I still do not regret buying it.
Kevin
   / My Ck25 HST psi ?? #7
It sounds like the dealer is going all out to make sure you get the proper fix. Please be patient as it sometimes takes Kioti a little time to get back to the dealers as they have a lot of new techs in the service department, and about 250 dealers to help.
All of this is warranty work, so you won't have to cover any of it. That's the good thing. John
   / My Ck25 HST psi ?? #9
What was the final outcome? I am having the same issues with my brand new CK20 4 hrs on it. TLB pacage.
   / My Ck25 HST psi ?? #10
gee whizz John.....I am not an kioti owner yet, but I'm still not sold on the HST, still putting my money on the GEAR. But I will contined to read and listen to you, and all the others information.......I think all brands have there days at times.
Poly Round Bale Ring (A50515)
Poly Round Bale...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Takeuchi TL150 (A50120)
Takeuchi TL150...
Barn Wood Bar Table (A50515)
Barn Wood Bar...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
