My CK20 Manual Transmission
   / My CK20 Manual Transmission #1
unkajed
My tractor now has 25 hours on it. Since day one, I have heard a knock. Perhaps I am not use to a diesel engine. I don't know.
Basically:
I turn on the ignition switch to glow plug. The glow plugs stay on for about 8 seconds or so. Glow plug light goes out.
I start the engine: Oil lamp/light goes out and I adjust engine speed to approx 1500 rpms and I let it warm up.
When I start it I hear knock, knock, knock. I hear this sound regardless of load, no load, rpm, transmission engaged or transmission not engaged.
The tractor is not smoking whatsoever.
I can make the knock go away by quickly lowering the rpm's via the throttle lever.
Let's say I am idling the engine around 1500 rpms. I adjust the throttle level all the way down to 1000 rpms which is the minimum rpm and the sound goes away until I guess it starts the injectors again to supply fuel to maintain the minimum rpm. Then the sound starts again.
Perhaps I am hearing Ignition Knocking.
Even though I am at 25 hours, I am considering changing the oil in case the tractor set on the lot for a while and perhaps the filter failed, is failing or something. Maybe the factory uses cheap engine oil for initial break in.
I know one thing. When I do change the oil, I am going to run the old oil through a pair of women's hose just to see if I have any metal particles.
If it is ignition knock, what can I do to quiet it down?? Higher centane rating?
It has not failed but it defintley sounds different than a gasoline engine.
I called my dealer and basically he said don't worry about it unless it fails.
Any suggestions or comments???
   / My CK20 Manual Transmission #2
It's probably just diesel knock but that is a diagnosis from xxx miles away without listening to the machine. Take it for what it's worth.
I have noticed the Daedong engines are MUCH louder than some others. My previous tractor was a Kubota and it purred once it warmed up. The 'ol Kioti definitely make more of a racket. I don't mind it really but I was surprised at first.
Thanks.. I am thinking the same thing. Especially since you say it is MUCH louder than some others.
Kill the fuel the knocking stops, re-apply the fuel, it starts again. Adjust the rpm downward and it stops.
I know if it was a rod or something, I would hear it all the time. I once has a car with a bad connecting rod bearing and it made noise when I applied gas or not. It never went away.
Maybe I am just freaking out.
Thanks again!.
{I would be pissed tho if something failed on this thing with just 25 hours on it since I bit the bullet and paid it off last month. I know Murphy and his laws.}
   / My CK20 Manual Transmission #4
Kioti Growl!!!!!!!!!
:D:D:D:D:D:D:D
BTI
:D:D:D:D:D:D:D
BTI
lol
Kioti Knocking Howl.
I take it not to many of these engines fail?
   / My CK20 Manual Transmission #6
If it continues to bother you then perhaps you could run a similar Kioti at your local dealer to compare.
Excellent Idea! Thanks
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Portable Restroom (A54865)
Portable Restroom...
2020 DRAGON ESP...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
